deleted wrote:
Dont have radio so not problem, but i might just leave the wire hooked up.
What i dont understand is where in the dizzy/igniter/coil circuit the +12v and - from the battery connect.
Do they simply just plug onto the + and - terminals of the coil?? alng with the wires that run to the igniter
This is where it gets hard to help from 1000kms away. I
think you just need to supply +12v feed from a source which is only on when the ignition is on, to the + of the coil - not direct from the battery!
From memory there were two wires from the coil to the ignitor (+ and -ve). The positive on the coil had one of those piggy back connectors so you could also attach the 12v feed from the appropriate source. The two wires from the ignitor to the dizzy (which you say you have done). There is also a wire from the ignitor to earth of course. That was it. In the email I sent there was a photo which showed the components spread out on the floor. The only thing missing (apart from the coil itself) was the +12v ignition feed to the coil.
Really would be good to get a friend to check it out before you put power to it though.
