It is currently Thu Jul 03, 2025 12:44 am
 Post subject: SUSPENSION MOD'S
PostPosted: Wed Nov 02, 2005 5:08 pm
DOES ANYONE NO IF ITS POSSIBLE TO PUT AIR BAG SUSPENSION UNDER A MINI SO ITS FULL ADJUSTABLE OR HAS ANYONE SEE ONE
CHEERS PAZZ, :shock:
PostPosted: Wed Nov 02, 2005 6:26 pm
http://www.ausmini.com/forums/viewtopic.php?t=8518
think thats in the uk i have no idea about any of that
PostPosted: Wed Nov 02, 2005 6:28 pm
Not only possible, but see this thread for video of an airbag ute... however, good taste will surely tell you it's a bad idea. Plus very expensive.
<edit> Ben ya beat me to it. yup, it's in Brighton, England.
PostPosted: Wed Nov 02, 2005 6:55 pm
Some even cam out with Hydro :shock:
PostPosted: Wed Nov 02, 2005 6:59 pm
that mini ute is hydraulic, not air bag.
it is to my knowledge imposible to fit 'bags' to a mini. cos they wont fit in a sub frame. there is a guy making a kit for a hydraulic set up in a mini which is going for about $3k sorry i cant be more helpful than that.
lookin for another clubby
PostPosted: Wed Nov 02, 2005 7:34 pm
If you wanted to do something along those lines, then just modifying the original mini hydrolastic suspebsion to hydraulic would be easy as :)
PostPosted: Wed Nov 02, 2005 7:57 pm
sweet as thank you what would have to be done to convert the old system
:lol:
PostPosted: Wed Nov 02, 2005 9:23 pm
a small hydraulic pump, a four way valve & another valve for up/down
plus a few hoses & fittings. Not very high pressure (300 - 350 PSI).
You could source these parts from an old wrecked crane - the outrigger control on our old Grove RT58B crane is a joystick-like 4 way valve that would be ideal :idea:
PostPosted: Wed Nov 02, 2005 9:39 pm
Could you run the pump off the Engine?
Copuse that could be Easy.. :wink:
PostPosted: Wed Nov 02, 2005 10:06 pm
Yeah, but I think it would be easier with an electrically driven hydraulic pump
just like they use for the tilt on big outboard motors...
PostPosted: Wed Nov 02, 2005 10:16 pm
i like that idea, if you do it keep us all informed!
Noli Illegitimi Carborundum
 Post subject: hmm
PostPosted: Wed Nov 02, 2005 11:48 pm
What about using a power steering pump, could allow minis to get over speed humps and through puddles
PostPosted: Thu Nov 03, 2005 12:04 am
that was my reason for fitting it (if I ever do)
but I think mike is right about the electric pump, no power drain!
PostPosted: Thu Nov 03, 2005 5:33 am
No good in a car required to handle properly - everytime you adjust height the camber and caster would go to hell. Might be OK for tootling around town or a show car though.
PostPosted: Thu Nov 03, 2005 5:46 am
You would not want it moving anywhere over 60 :?
Could send to the other side of the road
