It is currently Tue Jul 01, 2025 8:11 pm
 Post subject: Engine removal
PostPosted: Tue Oct 18, 2005 8:22 am
Can the engine from a mini with pot joints and a rod change gearbox be removed without taking of all the brakes, eg top and bottom ball joints. cause with the pot joints, i can pull the drive shaft out of the pot joint easily, while the pot joint is still connected to the diff.
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Tue Oct 18, 2005 10:18 am
Yeah, I think I remember just poping the top ball joint and being able to get the drive shafts out of the pots.
I'll be someone here has a better way...
PostPosted: Tue Oct 18, 2005 10:24 am
You can get away with only breaking one top ball joint, then moving the engine over slightly to allow the other driveshaft to be removed.
For ease, just break both ball joints!
Less farting around in the long run.
PostPosted: Tue Oct 18, 2005 12:31 pm
NAV-MAN
I have pulled a couple of pot joint engines without splitting any balljoints.
You just need to leaver it free of one and away you go, a bit of a tilt helps. The reverse is a pain though you just have to remember not to put too much grease in the pots but it can be done. just remember to pack the joints with grease before you put the boots back on
PostPosted: Tue Oct 18, 2005 10:31 pm
yeah easy,
first time i did it without undoing a ball joint,
then next time it was much easier when i undid one side.
