It is currently Wed Jul 02, 2025 12:59 am
PostPosted: Tue Oct 04, 2005 10:35 pm
got an 1100S block out of a granma's morris 1300 but it is auto and the
auto packed up at an original 70000kms
has any one done the automatic to manual conversion on an 1100S???
I have been told you have to drill out an oil auxilary or something???
Are 1100S blocks better if you want to build a big bore motor??
Round abouts are fun
PostPosted: Tue Oct 04, 2005 11:18 pm
OK it's all in here- http://www.ausmini.com/forums/viewtopic ... auto+block
I've done a couple now and am currently running one bored to 1360, on a Mk2 S box. No problems.
Read it thru, if you have questions, ask. 8)
Yes the 1100S, 1300 auto and 1275LS blocks are best for big bores.
PostPosted: Wed Oct 05, 2005 10:48 am
Cheers Dr
whats this S G/box
did they make tuffer G'boxes for the 1275???
or just different ratios
PostPosted: Wed Oct 05, 2005 11:19 am
The S gearbox he is talking about is the gearbox off a Mk2 Cooper S.
but AFAIK you should be able to put almost any mini gearbox on the bottom of it.
remote change boxes tend to help limit engine movement though, now that you have a 1275 8) :wink:
Added: the S gearbox probably got different ratios and there may have been some difference in the gearbox internals but it is not really nessicary to get an S gearbox IMO. Look for one from a mini K, 1100 remote change, deluxe etc (depends if you want a 4 synchro gearbox or not but 4 synchros is preferable) rod change gearboxes shold be fine too.
Roads need more corners
PostPosted: Wed Oct 05, 2005 5:52 pm
SlammedPV wrote:
Cheers Dr
whats this S G/box
It's a MK2 S box. Same gearbox as a Mini-K box except 1-2-3 ratios are slightly higher and output shafts/UJs are different.
Casing number is 22G1128.
All the 4 synchro boxes (including rodchange ones) are `tuffer' than the old 3 synchro ones including Cooper S Mk1. :wink:
