It is currently Tue Jul 01, 2025 8:08 pm
PostPosted: Mon Oct 03, 2005 9:23 am
If you are going to do extractors, go the whole hog and look into your collector pipe, main pipe and exhaust. If any of these are crap then extractors alone aren't going to make a huge difference.... If you are just going to whack any old extractors on (financially forced to do so) then just get Perry 3in1, they are great for small bore IMO and cheap!
Lillee - 1969 Morris Mini K
 Post subject: power= revs X torque
PostPosted: Mon Oct 03, 2005 9:32 am
Saying power= revs X torque is over simplifiying things. So is measuring peak hp to guage the effectiveness of a mod.
I have no idea why people cling to hp readings to 'measure' engines. Give me 0-100 and 70-120 elapsed times any day as they are real world measures. Readings between dynos mean nothing.
In the example above, sure peak HP might have been down, but might have been a smooth/higher torque curve throughout the range, giving a result of more usable power. Peak readings mean about as much as peak output readings on stereo spec sheets...
PostPosted: Mon Oct 03, 2005 10:50 am
already have an exhaust system on, 2" piping to a sports muff. Not getting the 3-1 extractors now changed my order getting LCBs you guys make them sound alot better than the standard 3-1
PostPosted: Mon Oct 03, 2005 12:24 pm
depends a lot on the design/size of the header, but in general LCB is seen as more applicable to big bore, 3-1 small bore.
PostPosted: Wed Oct 05, 2005 4:18 pm
fitted extractors (LCB) onto my motor just 2 weeks ago. also put whole new exhaust & mufffler set up on. 2inch centre exit with 2 nice n shiny outlets. at the same time replaced the old 1.25 SU with a bigger 1.5 SU mounted on a water cooled manifold. Moter size is 1100. Drives like its got a ton more power and sounds fantastic. still working out problem with a bit of a flat-spot when i put foot down though... anyone know anything about this?
PostPosted: Wed Oct 05, 2005 4:34 pm
You could use a thinner oil in the dash pot of your SU :idea:
The oil provides the damping to the rise and fall of the bell and needle in the SU carb so a thicker oil means that your throttle will be slower to respond, thinner and you will get a quicker throttle response AFAIK
If you go too thin there can be problems because the carb 'flutters' (varies too much and too quickly)
Roads need more corners
PostPosted: Wed Oct 05, 2005 5:48 pm
You probably now need a different needle in that SU. Sorry no recommendations- I run either twins, or Dellorto..
Check out www.winsu.co.uk
PostPosted: Sun Oct 09, 2005 3:30 pm
iv been told,by the previous owner,that i have cooper s extrators,are these any good,are extractors the pipes that run from the side of the engine and conect to your exhaust system,i have a feeling what im thinking of is the manifold,if so what are extractors, :oops: :D
PostPosted: Tue Oct 11, 2005 4:50 am
A whole lot of terms get used interchangably in this area. Generally when people use the term manifold on it's own they're either talking about a seperate inlet manifold, or the factory set up with the inlet manifold and exhaust manifold cast in one piece. Cut them apart and you've got an inlet manifold, and a boat anchor. Throw the exhaust side away and what you replace it with is extractors, or headers ('merican). So yes, sounds like you have the 'cooper' 3 into 1. Sits between the head, and meets your exhaust system somewhere at the bottom of the firewall.
PostPosted: Tue Oct 11, 2005 11:05 am
Hertiage MG parts in Smithfield NSW has LCBs for around $150
9608 3988
they also courier
Inconspicuously Conspicuous
PostPosted: Tue Oct 11, 2005 5:44 pm
got my LCBs for 180 delivered put them on next week
PostPosted: Tue Oct 11, 2005 6:08 pm
any idea who sells stainless LCB's? I am in bris so preferably somewhere around here...but i spose if shipping isnt like $1000 it wouldnt be terrible to get it posted from syd/melb...
preferably high polished stainless too :)
Bling me up Scotty!
PostPosted: Wed Oct 12, 2005 5:25 pm
MiniSpares UK do them (Maniflow ones) not sure of cost. check on www.minispares.com
Karcraft don't carry them, but might bring in special if you ask nice. :wink:
PostPosted: Wed Oct 12, 2005 5:30 pm
ugggh...how is it that we have the highest number of original minis and yet the lowest number of modern dodads for them? if you could take our minis and mix them with the UK's market...we'd all be in heaven...
anyway :) thanks for the advice...i'll give them a ring and see tomorrow
Bling me up Scotty!
PostPosted: Wed Oct 12, 2005 9:44 pm
Man inazuma_x what is with you and Stainless Steal doesnt make you go any quicker :?
Users browsing this forum: No registered users and 25 guests
