It is currently Sat Jul 19, 2025 1:19 am
 Post subject: indicator stick flicking
PostPosted: Thu Aug 25, 2005 11:07 pm
ok so since ive been driving a bit more recently ive had a tiny problem thats been with the car the whole time that has never really bothered me but now its kinda getting annoying. at night when im drving, the lights someimes flick onto high beam especially when i just completed a turn and when the indicator flicks off. sometimes it even flicks on the high beam instead of turning off the indicator. but yer does this happen to you guys too? and how did u stop it? I bet theres just some screw or something i need to tighten just thought id ask, cheers.
PostPosted: Thu Aug 25, 2005 11:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
stalk sounds to be stuffed might need a new one
makka
PostPosted: Fri Aug 26, 2005 8:54 am
G'day.........I think the same sort of problem existed on Ribena before I bought her. The previous owner cut the two wires to/from the headlight dip switch and installed an old Morry 1000 foot operated switch - works a treat. Better than the original set up imho
Hooroo :)
Rod Image
PostPosted: Fri Aug 26, 2005 8:38 pm
ill just put up with it until it breaks or something lol
PostPosted: Fri Aug 26, 2005 8:50 pm
why dont you pull the indicator stalk off and have a look? Its only a couple of screws, and might be 2 wires touching, might be easy to fix :wink:
www.crazybitchracing.com
