It is currently Wed Aug 13, 2025 1:18 am
 Post subject: Help Needed Urgently
PostPosted: Wed Aug 24, 2005 3:19 pm
Hey Guys and Gals,
I am rebuilding my rear drum brakes ... they are finished and im trying to put them back together, but the outside casing of the drums wont fit back on ... it seems to get stuck against the brake pads ... then when i manage to force it on, the wheels wont spin at all.
HELP ME ... i cant do anything further to the car until i work this out
Lucas
PostPosted: Wed Aug 24, 2005 3:22 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
back the slack adjusters of oppisite direction of the way the wheel turns
makka
PostPosted: Wed Aug 24, 2005 3:23 pm
Did you let the adjustment bolt screw bit off ?
Sometimes the wheel cylinder is not centred either so it makes it hard to get the drum on :wink:
Roads need more corners
PostPosted: Wed Aug 24, 2005 3:24 pm
Slack adjusters ??? Are they the thing on the opposite end to the brake cylinder?
PostPosted: Wed Aug 24, 2005 3:25 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
on the backing plate there is a square looking thing that is the slack adjuster
there are two on the front
makka
PostPosted: Wed Aug 24, 2005 3:26 pm
okay ill try it ... back in 5
PostPosted: Wed Aug 24, 2005 3:39 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries
makka
PostPosted: Wed Aug 24, 2005 3:47 pm
yep, keep turning that sucker till you fit the drum on, then adjust back up. The difference between old worn out shoes and new shoes is a LOT of turns.
PostPosted: Wed Aug 24, 2005 3:48 pm
Got It!!!
The two little metal pieces inside the adjuster were in upside down
derh!
Thanx makka
PostPosted: Wed Aug 24, 2005 4:10 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries mate
makka
Users browsing this forum: No registered users and 242 guests
