The valve cant be shut as I was able to lock both fronts and rears up on gravel. I dropped it off at the brake place, they'll adjust the rears and hopefully rebleed the system, hooooooopefully for better pedal/brakes
It was interesting that at slow speed (1st gear coz I only had a small amount of gravel to play with) the rears locked up, but not the fronts till Id almost stopped. I put it into reverse and tried again, the fronts locked up but not the rears.
Last time I tried the lockup thing (bout 3 weeks ago, before M/C changeover) I was going a bit faster in 2nd gear, all fours locked up pretty much same time.
Edit: Got it back from the brake guys and they adjusted the rears, pedal is better... seems its as good as its gonna get.. looks like I'll be adjusting the rears on a monthly basis
