It is currently Sun Jun 29, 2025 2:00 pm
PostPosted: Mon Aug 15, 2005 10:08 am
Can anyone recommend where to get a stock 1100 head converted to ULP?
Are the valves machined/replaced in the same process?
What cost should be expected?
PostPosted: Mon Aug 15, 2005 12:22 pm
any machining shop and some mechanical places would be able to do it
not 100 percent sure what they do i think they put harder guides
should be around 100-200 i would think
PostPosted: Mon Aug 15, 2005 2:09 pm
Some of the other guys on here will tell you more about it but AFAIK hardened valve seats and new exhaust valves for one. Talk to your machining shop
Cost depends on what you want to do with your head and what other bits and pieces need replacing and / or upgrading.
The ULP conversion is mostly(read all) on the exhaust side of things so inlet valves guides etc don't have to change unless they are worn already :roll: may as well get the rest of the head looked at while your at it IMO :wink:
Roads need more corners
PostPosted: Mon Aug 15, 2005 5:23 pm
Russell Engineering here in Sydney gets another machine shop to do it, I think it costs $140 just to supply & fit the inserts in. You should fit new ex valves and valve guides to make a proper job of it.
Anton (J_A_M) got his 202 head done recently...
PostPosted: Tue Aug 16, 2005 10:59 am
I took it to a local engine reconditioning workshop - not a Mini specific place.
They charged $35 per exhaust seat to fit stainless seats. Stainless valves are optional and not necessary.
All up I paid $240 to have them blast and clean the head, fit the hardened seats, recut them, machine the head face, fully assemble and test the head. I supplied new valves and guides.
It looked a million bucks when it was done. I don't think I took a pic.... :(
Money well spent I say! 8)
PostPosted: Tue Aug 16, 2005 1:01 pm
That price is very affordable, now all I need to do is find a local head shop, although I do travel to Melbourne quite often so I might source someone down there.
Thanks for the replies guys.
PostPosted: Thu Aug 18, 2005 10:43 pm
nice price!
PostPosted: Thu Aug 18, 2005 11:20 pm
hey JAM so Who is your enigne Running now? did u notice anythin? were did u purchase the valves and guides from?
PostPosted: Fri Aug 19, 2005 7:20 am
he got them from Karcraft. I fitted the guides in. :wink:
