It is currently Tue Jul 01, 2025 5:16 pm
PostPosted: Fri Jul 29, 2005 5:29 pm
meeni, I found that with a bit of moving things about and that sort of fiddling I could move the top arm out without taking the shaft right out. I didn't even have to split the ball joint :D :shock:
Roads need more corners
PostPosted: Sat Jul 30, 2005 1:34 am
I had my front trumpets out AND back in within half an hour on each side. No cone compressor, I just pulled out the top arm shaft enough for one end of the top arm to drop down.
You need to think 3 dimensionally when working on these cars. If something doesnt come straight out, what needs to be removed?
PostPosted: Sat Jul 30, 2005 4:17 pm
yay, job done now, thanks for your help everyone, i will put pics up soon!!! :D
Potato
PostPosted: Sat Oct 29, 2005 7:18 pm
Aheeeem, BUUUUUMP.
Ok, I bough a nice shiney set of Hilos, however I have one issue... the bolts holding the springs in the front wheels have been scuffed flat, so I can't get them out with a spanner...
First of all, has anyone had this problem? how did you deal with it?
Personally I am going to lube it up and try again, and if all else fails, saw the damned things off and replace the whole bolt.
1978 Mini Clubman 998cc...for now
PostPosted: Sat Oct 29, 2005 9:27 pm
I dont quite understand what bolt you are talking about.. But if its stuffed and you cant use a spanner on it maby try using some vice grips? But it will have to be replaced afterwards...
Life's a garden.... Dig It!
