It is currently Thu Jul 03, 2025 5:29 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Jul 13, 2005 9:55 am
the volvo calipers are cast steel I think
When they use them on commodores they put a spacer betwwen the two haves to suit the different thickness.
So I took the calipers to work last night to clean them up........... and they are from a camira......... with solid disc rotors....... darnit. I have to take them back. 40 bucks for the pair.
PostPosted: Thu Jul 14, 2005 9:42 pm
btw can anyone tell me the inside diameter of 12' rims?(contessa style) I have now got the correct setup... camira calipers as per pictures. The diameter needed to clear is about 11 inches or close to it. (275 mm)
PostPosted: Fri Jul 15, 2005 11:42 am
just a word of warning... the set i bought from the guy in Camden were NOT engineerable.... Somthing about the brackets I had not being true and placing the callipers over the same amount of surface on the disc...
So buyer beware...
68matic: "i havent seen much head in my life "
PostPosted: Fri Jul 15, 2005 5:36 pm
So buyer beware...
Can these particular ones be modified to be 'LEGAL' ?? I bought a set off the same guy in Camden that is all....
Life's a garden.... Dig It!
PostPosted: Fri Jul 15, 2005 7:15 pm
The ones I saw looked well made, if both brackets are made the same I can't see the problem.
Certainly they look better set up than my Honda Citys, which 13secmini's engineer said he would have passed (with Starlet turbo power) if they had been ventilated. :wink:
PostPosted: Fri Jul 15, 2005 7:31 pm
So Nuclear's ones were not able to be Engineered beacuse the brackets he had were different?? Ohh well ill just have to see how mine goes, still a long way away from getting anythin engineered yet
PostPosted: Sat Jul 16, 2005 12:39 pm
hey has anyone got any sepeate pics of just the bracket for the camiras? i found out at work yesterday you get get drilled/slotted rotors for them, i recon they'd look pretty cool behind my new 13's...
have a honda setup, but these camiras sound a lot better.. 8)
GTi Turbo'd mini, abused daily
PostPosted: Sat Jul 16, 2005 1:36 pm
For those interested.
The camiras with vented discs were the JD and JE models 1984 - 1989. This should help you guys abit when finding parts. I got this info of the DBA website so it should be accurate.
Cheers, Cazmo
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Sat Jul 16, 2005 1:37 pm
998 - if you sell your current brakes it should pay for the new wheels and the camiras :P
PostPosted: Sat Jul 16, 2005 2:22 pm
the slotted and cross drilled are 260 each from supercheap!!
I got two discs second hand, rusty but no scoring for 40 bucks...
PostPosted: Sat Jul 16, 2005 2:50 pm
We used to get Honda Civic calipers, good discs, bolts & hoses for $40... the lot! :lol:
PostPosted: Sat Jul 16, 2005 5:34 pm
hey has anyone got any seperate pics of just the bracket for the camiras?
yeah id like to see some too!
PostPosted: Sun Jul 17, 2005 12:21 am
In the first few photos on this thread I noticed some tabs on the opposite side of the caliper, why are they there? they are part of the adapter plate, are they there to stop the brake lines from rubbing? or are they to stop full lock?
PostPosted: Sun Jul 17, 2005 7:33 am
If you mean the lugs near the hose fitting- I think like the Hondas, they are there to help stop the banjo end on hose from unscrewing.
PostPosted: Sun Jul 17, 2005 10:15 pm
I don't mean on the caliper, but the steel tab on the Right of it. (as seen in very first Pic)
