It is currently Sun Jun 29, 2025 4:05 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jul 08, 2005 10:12 am
There has been some talk of putting a echo motor in a roundnose mini, so i went looking for info.
The best motor the aussie cars got was the 1.5L in the vvti echos, 1 NZ-FE this puts out 80kw. Looks like a very compact motor.
This is a 1L echo motor with a HKS turbo kit making 100kw on 6psi.
http://toyotaownersclub.com/forums/inde ... ery&id=997
I have also found out that somewhere in europe that there has been 400 factory turbo echos made. From what i can translate they are called yaris TS turbo. They put out only 150hp but are running like 5psi. These are getting built by TRD and look like they will mass produce them soon. But countries with high emmision regulations like UK will not be getting them, probably same here. There is also a another one called Vitz RS turbo, think these are in japan.
More info on it here:
http://benjaminpirone.free.fr/TOYOTA_YARIS_Turbo.html
So who out there has a sister or mother with an echo in there driveway?? Go get the tape measure out :D
1974 Moke - 998cc
PostPosted: Fri Jul 08, 2005 10:43 am
thats a nice little find of info Brad.. :wink:
Cody
PostPosted: Fri Jul 08, 2005 1:24 pm
Yeah Brad, that's the echo thing I was talking about. As doc says may be too tall instead of too deep. But hey it looks close. Wait a couple of years for the Japs to wrap them around trees and we will have a ready supply of sports engines :D
PostPosted: Fri Jul 08, 2005 2:29 pm
i dont think there that tall really,,, have a look at the motor in relation to the top of the suspension tower in the first picture. It sits way under it and the starlet motor in mine sat above them i think. maybe an optical allusion......
1974 Moke - 998cc
PostPosted: Fri Jul 08, 2005 2:30 pm
dude at work has a echo... will look on Tue when i am back at work... measure it all up
PostPosted: Fri Jul 08, 2005 4:15 pm
the motor looks pretty small :)
PostPosted: Fri Jul 08, 2005 4:45 pm
wow ben great pictures mate :D
Dosnt have the sump on it but that does look alot smaller then the 4efte.
Now we just need a pic without all that plastic crap so we can see where the inlet and outlets are. Looks like to me on those pics the inlet is on the front of the engine :shock:
1974 Moke - 998cc
PostPosted: Fri Jul 08, 2005 4:49 pm
also looks like the fuel rail and injectors go into the head and not the manifold :?
PostPosted: Fri Jul 08, 2005 4:54 pm
I knew they would have to do something funky to get it to fit in an Echo. Also is it just me or does that gearbox look like an exact replica of the 4E one just shrunk down...
Also got MiniVan Japanese Pics (slightly different turbo set up I noticed? Looks aftermarket given BOV etc)..
PostPosted: Sat Jul 09, 2005 5:48 pm
that looks like a brads motor definatly not a echo motor
PostPosted: Sat Jul 09, 2005 6:43 pm
Brad, look at the bottom- I think the sump (flat one?) is there, if not what's that black thing bolted up all around there...??
PostPosted: Sat Jul 09, 2005 8:46 pm
Guys,
I cant see where the enfgine mounts are either - I wonder if it is similair to the Starlet?
And whats that circular cutout at the rear end of the casing? :?
Andrew
PostPosted: Sat Jul 09, 2005 8:54 pm
Archangel007 wrote:
Guys,
Andrew
id say starter motor spot
 Post subject: Trial Fit
PostPosted: Sat Jul 09, 2005 9:00 pm
can someone please photoshop that into a Mini...as a trial fit :lol:
PostPosted: Sat Jul 09, 2005 10:52 pm
Andrew, given that triangular bolting pattern I would say a very close approximation to the Starlet engine mount arrangement at least on the left hand side...
Users browsing this forum: No registered users and 25 guests
