It is currently Sat Jun 28, 2025 6:15 pm
 Post subject: Not Long Now
PostPosted: Fri Jun 17, 2005 7:52 pm
I got my gearbox back today. Mk 2 s box with 3.65 diff so i hope to have it all up and runnin in three weeks time. and then i will replace the twin su's with my 45 webber on redline maifold. I am also thinkin of cutting and then making brackets so i can remove the peice behind the mostache on my roundy for easyier access like a cluby. Has anyone done this before. but it seems pretty easy.
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Fri Jun 17, 2005 8:38 pm
sounds like a nice setup.... Just make sure that part you want to cut can be bolted in secure as its a pretty structle part of the front and also holds the bonnet down.
1974 Moke - 998cc
PostPosted: Sat Jun 18, 2005 6:10 pm
yeah i'm goin to weld some plates on and bolt it up.
 Post subject: Hmm
PostPosted: Sat Jun 18, 2005 11:01 pm
Sounds like an interesting mod but..... How often would you get the advantage of doing this?
PostPosted: Sun Jun 19, 2005 11:55 am
well i have had the car for about 15 months now and the engine has been out 4 times. for one reason or another. but just think easy access to the dizzy. easy to pull the engine out. and it will only take about an hour anyway. i will take pictures of when i doit and post it
PostPosted: Sun Jun 19, 2005 6:24 pm
made sum progress. checked the end floats for the idler gear and the primary gear and they are good i will be posting sum pics up later.
