It is currently Sun Jun 16, 2024 6:27 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 19, 2024 5:56 pm
68+86auto wrote:
The dwell angle is the number of degrees per cylinder that the points are closed/coil charging in one rotation of the distributor. Electronic ignitions work the same way.
Maybe some but by no means all..... Many EIs have single trigger point (Pertronix uses a magnetic signal while my old Piranha uses an IR beam/chopper). The timing is set using pretty much the same system as a points setup in the the coil (and plugs) are fired by the points opening or magnetic/IR pickup triggering.
With points, they close and the coil is charged until the points next open... With EIs, the little black box switches the coil charge on based on some form of logic in the box. Presumably it's time related because there's no sensor available to measure any rotation of the dizzy....
EIs work better because A. they don't wear like points; B. they don't suffer from spark scatter due to a worn dizzy shaft (so timing is more accurate and stable) and C. (one assumes because I really don't know) they can vary the voltage/current fed to the coil to compensate for the reduced coil charging time as revs rise. (I've not found an explanation for what/how the circuit(s) inside the little black box on my Piranha do)... but they're there so they must do something.....
Cheers, Ian
PostPosted: Fri Jan 19, 2024 7:37 pm
Cheers, Ian
The dwell is still read exactly the same way. In fact the scope pattern for electronic ignition systems is very similar to points ignition since it all works the same way.
Too many minis
PostPosted: Sat Jan 20, 2024 5:22 am
I am not convinced that electronic triggers do not suffer due to a worn shaft or bush as that still has the same effect on the trigger ring. Obviously a worn cam or points heel would not affect it though.
Cheers Dave.
PostPosted: Sat Jan 20, 2024 7:13 am
They do suffer it is just not as noticeable.
Too many minis
PostPosted: Sat Jan 20, 2024 11:34 am
When measured on a dizzie test machine my Piranha showed no differences between a 60 years old S dizzy and a brand new Aldon... nothing like the results when using the points setup...
Cheers, Ian
PostPosted: Sat Jan 20, 2024 4:57 pm
I built up my current 43D from bits, there was no bush in the body so it now has a roller bearing at top (as per Vizard's book) and a 'drmini' bronze bush at the bottom.
With the old Triger cam belt kit there is NO spark scatter.
