It is currently Tue Jun 24, 2025 7:14 am
PostPosted: Mon Jul 24, 2023 2:14 pm
Yes they are reputable suppliers.
A picture tells a thousand words.
PostPosted: Mon Jul 24, 2023 2:42 pm
Only other thing I can suggest is are they the correct way up? One end has a straight shank and hook, the other a shorter shank and more rounded hook.
That's really the limit of my knowledge and experience on the topic. Hopefully someone else can assist.
PostPosted: Mon Jul 24, 2023 2:56 pm
Tried both ways.
PostPosted: Mon Jul 24, 2023 3:57 pm
They are rubbish now compared to UK originals. Not made same.
Probably Chinese Replacement Auto Parts.
The inner end of the 2 hook wires are just bent, not shaped to a pad.
Last edited by drmini in aust on Mon Jul 24, 2023 5:03 pm, edited 1 time in total.
PostPosted: Mon Jul 24, 2023 4:06 pm
I watch a lot of FB videos out of Pakistan. I have an inkling a lot of our parts are made directly from scrap steel out of that place.
PostPosted: Mon Jul 24, 2023 4:31 pm
You can see on page 27 of the manual gtogreen posted on the other drop test post that the springs are fitted with the circular end of the spring on the throttle linkage. To me that means the shank of the spring is effectively pulling from the centre. If the spring was fitted the other way around it is slightly pulling off-centre and at a slight angle, not directly down. Whether that makes a difference and whether it’s part of your problem I don’t know but from a simple mechanics viewpoint I reckon it makes sense.
Edit: Your pics show the way I’ve suggested is correct with the loop at the top so obviously it’s not the reason for your problem.
PostPosted: Mon Jul 24, 2023 6:31 pm
Just to repeat myself, I have tried them both ways round.
PS It is very easy to dismantle the hooks from the springs.
PostPosted: Mon Jul 24, 2023 6:52 pm
I must have been lucky with the English supplier I used....
PostPosted: Mon Jul 24, 2023 8:05 pm
Maybe I have the shield on backwards judging by ausdino's above picture.
PostPosted: Tue Jul 25, 2023 1:02 am
The return spring bracket between the two heat shield halves can also go ont two ways - may be worth a check.
PostPosted: Tue Jul 25, 2023 9:15 pm
Consider SU Midel. They advertise return springs by "Terry's" who were a top spring manufacturer in UK for a long time and made most original equipment for the auto industry. They might still be a quality item.
PostPosted: Sat Jul 29, 2023 4:04 pm
Here is OLD & NEW. The hooks on the OLD springs don't fall out like the NEW springs.
I am looking for 2 old style springs for my twin SU setup.
PostPosted: Sat Jul 29, 2023 6:32 pm
Can you not use a standard spring similar to the single su springs?
Cheers Dave.
