It is currently Fri Jun 27, 2025 6:37 am
PostPosted: Thu Dec 22, 2022 5:09 pm
Hi all,
I’ve started reassembling my Mk2 CS jigsaw puzzle after a respray.
Problem is that I didn’t pull it down all those years ago.
It’s been in a million pieces since 1995.
So, I will be making new hydro pipes and I am wondering if there’s a specific order for all the pipes and battery cable under the metal covers.
Eg passenger side, is it hydro pipe on the outside and fuel line on the inside?
Similar question for the driver side. Hydro pipe to the outside and battery cable inboard?
I reckon that they’ll go in there anyway that fits but does anyone know what was the factory sequence
Thank you
Neil
PostPosted: Thu Dec 22, 2022 9:19 pm
I have some sketch diagrams of the pipes made when pulling things apart.
Happy to post them here but others may have better photos.
My notes have the LH hydro pipe towards the centre of the car and petrol pipe running beside the swage line and towards the outer edge of the channel.
RH has hydro pipe down the middle of the channel covered by the skid strip cover, and brake line alongside outer swage line (mirror of other side's petrol line) and battery cable running between them.
There are pieces of spiral cut plastic hose for all the pipes to prevent rattles where the tangs retain them.
If you haven't done hydro lines before now and don't think in 3 dimensions well, suggest that you form the lines with the shell on its side for easy access, if that is possible. Working upside down was a real struggle for me.
PostPosted: Thu Dec 22, 2022 10:18 pm
Neil,
Just checked my photos, hope these help. White one was reassembled as I removed them, red one was a jigsaw puzzle, disassembled by PO.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Dec 22, 2022 10:44 pm
Neilwillo wrote:
Hi all,
I feel your pain..... mine has been apart since 1983, and a house move. No smart phones then, but some consolation, at least I did it and bagged/tagged/bottled most things. Still cant find the jack....
Mine had no pieces of hose on the brake or fuel lines. It had the green spiral hose pieces on the hydro lines like cgo's.
Great pictures Clive.
PostPosted: Fri Dec 23, 2022 5:22 am
ausdino wrote:
Neilwillo wrote:
Hi all,
Thanks Ausdino for mentioning the pieces of hose, the green hose is original. I did add non-original short pieces of plastic hose to the the brake and fuel lines.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Fri Dec 23, 2022 4:51 pm
....and what a good idea. I'll do the same at the hard points where the pipes meet the body/clips.
PostPosted: Fri Dec 23, 2022 5:08 pm
The short lengths of black rubber hose over the brake and fuel pipes have part numbers - 6K751 for the brake pipe and 6K838 for the fuel pipe.
I got some NOS of each from John Smidt many years ago because he had them, but similar split black hose would do the same job.
PostPosted: Sat Dec 24, 2022 6:48 pm
My notes....<snip>
Thanks for posting this Bill. This is a big help. My old pipes have the correct plastic, spiral covers on them so I will be moving them to the new pipes.
I was looking at the options for bending up the new pipes and I will look at forming them while it’s still on the rotisserie. I reckon that I would have too much trouble doing that job from underneath.
It’s still a bare shell at the moment and I’m pumping Tectyl into every cavity then rotating the shell on the rotisserie to get it to run upside down and sideways. It’s oozing out everywhere :D
Merry Christmas
Neil
PostPosted: Sat Dec 24, 2022 6:58 pm
cgo wrote:
Neil,
Thanks for the images Clive,
They are a big help.
Interesting that both green and black plastic covers were used on the hydro pipes back in the day. I have mostly black but I have a single green on each hydro pipe.
Not in the same spot though
Neil
PostPosted: Sat Dec 24, 2022 7:07 pm
ausdino wrote:
Neilwillo wrote:
Hi all,
Yep, it’s the little things that are a challenge for me.
It might seem simple and doesn’t really matter but just as simple as the pipes and cables sitting in the right order is important for me. Might be a bit OCD but it’s going to make for a better car.
It’s going to come together, albeit slowly.....
Neil
PostPosted: Sat Dec 24, 2022 8:10 pm
Another photo, this one showing the position of the battery cable. This was the arrangement before disassembly in 2015, it may have been changed by a PO prior to 1978 when I bought the car, so it may not be the original arrangement.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Sun Dec 25, 2022 1:59 pm
Does the battery cable go under or over the rear subframe?
PostPosted: Sun Dec 25, 2022 4:41 pm
Ah the age old question :D
PostPosted: Mon Dec 26, 2022 9:49 am
My vote is outside of subframe - not between body and subframe.
My Mk2 is as above (although rebuilt by me twice); mini K same (owned from new and never removed subframes).
This is the setup I have:
And not this:
PostPosted: Mon Dec 26, 2022 10:38 am
Was that bracket on the rear subframe specifically there for the battery cable “p” clip ?? Looks a better way to route the cable. Mine has been apart way too many years to remember how it was (39 years). Thanks everyone for the info, will be handy when I get to this stage.
