It is currently Thu Jun 26, 2025 3:06 pm
 Post subject: Mini Tie Rod End
PostPosted: Sun Nov 20, 2022 5:22 pm
Approximately how many turns should each tie rod end be screwed to the steering rack?
 Post subject: Re: Mini Tie Rod End
PostPosted: Sun Nov 20, 2022 5:29 pm
A minimum of 1.5 times the thread diameter, then so they’re equal and the toe is right
You can get extended ones for a bit more thread engagement
PostPosted: Mon Nov 21, 2022 8:19 am
Step 1: measure the length of tie rod end you are replacing and compare to the replacement (to check they are the same)
Step 2: count the turns when you remove the old unit
Step 3: Fit the new unit by winding it on the number of turns you previously counted
Step 4: To be sure, get the toe in/out checked
