simon k wrote:
Slightly obvious question you may have already thought about and answered.. do you have a tacho? what's the idle speed?
Going by those plugs (aside from #3), it's running pretty rich, were the plugs you took out that dark? ever had a look at the plugs after a good 15-20 minutes at 100kph?
How does it perform if you drive it up a hill in 4th gear? - like the kind of hill where you start at the bottom at 3000rpm and you floor it, the engine holds those revs and chugs all the way up, maybe dropping to 2000rpm at the top.. is it happy to do it, or does it cough and miss and stumble and you have to drop back some gears to get it to rev
When i checked the idle speed on my digital timing light a few weeks back, I believe it was around 800rpm at idle.
Now that you mention the colour of the plugs, I've done a bit of reading and they do appear a bit dark don't they. I've been out of the car scene for a few years and just naturally observed the electrodes and the very end of the tip.
To be honest the car doesn't get as much of a workout as it should. Most of the time it doesn't reach past 60km/h (around town driving). I think naturally I would drop down a gear if climbing a hill. Hopefully, this rain settles and i can give it a good drive, I'm a bit precious of the old girl in the rain
I'll chuck a new set of plugs in, rotate the dizzy drive and lean it out a bit. And then see if the problem transfers to a different cylinder.
One thing that I have noticed recently is that sometimes the vibration at idle is worse and sometimes it's slightly better (Still present though). I guess this is like a lot of issues though, sometimes they flare up.
