It is currently Sat Jun 28, 2025 5:16 pm
 Post subject: Mini Wiring Loom
PostPosted: Mon Jul 11, 2022 2:46 pm
Just bought a Vinwiring loom and was wondering what root the dash wiring should take. There are 3 holes in the front parcel tray. Should all the 3 wiring branch go through the larger centre whole or should they be split the utilise the remaining smaller outer holes for the lesser wires.
 Post subject: Re: Mini Wiring Loom
PostPosted: Mon Jul 11, 2022 7:20 pm
All wiring should go through the central hole - nothing in the other holes.
PostPosted: Mon Jul 11, 2022 8:13 pm
and don't neglect to put a large holey grommet in the hole first.
PostPosted: Tue Jul 12, 2022 10:25 am
Where can I buy the holey grommet from and/or what is the part number.
PostPosted: Tue Jul 12, 2022 10:33 am
My 850 book has it as 3H1457 (GROMMET 1-3/8 x 3/4).
PostPosted: Tue Jul 12, 2022 10:36 am
Where can I buy the holey grommet from and/or what is the part number.[/quote]
I'd like to know where to get one of those too - can't find anyone selling that size.
And realise the clubman minis had a large diameter grommet than round nose.
PostPosted: Tue Jul 12, 2022 11:43 am
Hello All,
I'm not sure of the dimensions, but would Lucas grommet #C555 be close?
Regards,
Glen
PostPosted: Tue Jul 12, 2022 12:47 pm
And realise the clubman minis had a large diameter grommet than round nose.[/quote]
I bought from a local rubber goods supplier based on size.
PostPosted: Tue Jul 12, 2022 2:01 pm
So the grommet is 35mm x 19mm, is that a correct calculation?
PostPosted: Tue Jul 12, 2022 2:27 pm
Clark Rubber sells grommets as per the following list...
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Tue Jul 12, 2022 2:30 pm
I found something that worked from Clark rubber. I think it was a blank that I cut a x in
Ah, I see Oscar beat me to it.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Tue Jul 12, 2022 2:35 pm
Thanks Rod.
I found they list 15728 as 34.5mm X 20mm, which is close to the panel hole size. When you search their site, computer says "Nah" - as in "no record".
PostPosted: Tue Jul 12, 2022 3:06 pm
No wuks Bill. They are available mate. You just have to blunder around a bit :lol:
I'm glad I found this listing as I need a handful of varying sizes for a Pulsar GTIR project I'm playing with atm!
Rod.
PostPosted: Tue Jul 12, 2022 3:59 pm
I think I've found where I can get the right sized grommet for my parcel shelf wiring loom hole. The hole is 35mm in diameter and Clark Rubber chart above shows a thin grommet Item no. 726 which appears to have all the right measurements. Thank you all for your input.
PostPosted: Tue Jul 12, 2022 10:25 pm
You're a better web blunderer than me Oscar. Still no listing from Clark Rubber.
If I have to click and collect at Geelong from Sydney, I might need 36 months of interest free payments.
Users browsing this forum: No registered users and 72 guests
