It is currently Wed Jul 09, 2025 12:29 pm
PostPosted: Tue May 10, 2022 5:52 am
Hello,
I have the above Mini Copper which is fitted with NGK BPR6ES spark plugs and running on unleaded 95 petrol. I am looking to get a new set of plugs so I removed one of the plugs the other day which seems a little lean to me (see the attached photo), however maybe this is all correct for this Mini - also, are the NGK BPR6ES plugs correct for this model and if so, what gap should they have? Cheers
PostPosted: Tue May 10, 2022 7:42 am
BPR6ES are the correct plugs and the gap should be the standard 35 thou.
I would suggest 98 unleaded
The plug does look a little lean but you did not say whether it is a carb or injection.
Cheers Dave.
PostPosted: Tue May 10, 2022 9:13 am
Injected I reckon, doesn't sound like it would have been converted to carb..
If it's just one of the plugs then I'd be thinking about a leak down test, those white deposits could be oil. Try a hotter plug - BPR5ES
PostPosted: Tue May 10, 2022 6:58 pm
Thanks for the info. I'll try a new set of BPR6ES with a gap of 35 thou which is .889mm and see how she goes and I'll also try running on 98 unleaded as well, cheers
PostPosted: Fri May 13, 2022 10:34 am
Check your other plugs. It's not that uncommon for 2 cylinders to run leaner than the other two on an injected mini - particularly on early models and on later cars if the inlet manifold was replaced with an earlier design one, or incorrectly 'performance modified'.
