fffffred wrote:
I've checked the gauge, it's pretty accurate. In fact last month, my fan belt snapped, and because I had a faulty alternator, I ignored the light until I saw on my gauge, the water went past 100 deg C so I pulled over... the thermostat may have stuck open since then. I'll renew it for piece of mind. I just hate green liquid...
I suspect that this is your issue.
It’s not uncommon for a thermostat to jam open after an overheat situation. From memory some of the better brands are designed to do exactly that. Can’t remember what brands though. The red coolant is worse than the green... Toyota use red and it oozes everywhere
Neil
