It is currently Sun Jun 29, 2025 1:12 pm
 Post subject: Mixture question
PostPosted: Mon Aug 02, 2021 9:26 am
1275 engine and No 1 & 4 always burn leaner than 2 & 3 which is a quirk of the A series.
Question is I assume it is better to have 1 & 4 correct with 2 & 3 somewhat rich rather than running the outer 2 cylinders lean?
Cheers Dave.
 Post subject: Re: Mixture question
PostPosted: Mon Aug 02, 2021 8:19 pm
Oh dear, worry, worry...
Hi Steam
If your mixtures are correct it's not really a problem, but if your are worried about it you can run one heat range colder on 2 and 3 as BMC did back in the day :) in competition, some times they run higher compression in 2 and 3 (one point higher)
Graham Russell
PostPosted: Thu Aug 05, 2021 10:19 am
What air-fuel ratios (using a wide-band O2 sensor to tune) are normally used at cruise and full load?
- 1968 Australian Mk1 Morris Mini (originally a MiniMatic but a previous owner converted it to a 1275 and rod change box)
- 1964 Lotus 23B
PostPosted: Thu Aug 05, 2021 8:18 pm
HI Murty
With the SU caries 14 to 15 on cruise full load 13.5 to 14
With webers 13 to 14 on cruise full load 12.5 to 13
Graham Russell
PostPosted: Thu Aug 05, 2021 11:54 pm
Thanks Graham
- 1964 Lotus 23B
PostPosted: Fri Aug 06, 2021 9:38 am
GR wrote:
Hi Steam
Graham Russell
Thank you Graham, excellent advice as usual.
It is not worrying me enough to change the inner plugs, i will keep 1 & 4 Correct with 2 & 3 slightly richer. All good.
Cheers Dave.
Users browsing this forum: No registered users and 112 guests
