It is currently Sun Jun 29, 2025 6:01 am
PostPosted: Tue Apr 20, 2021 10:21 pm
The headlight dipper switch on 1970 minis was floor mounted.
Question: was there a terminal block to hold the 3 wires doing to the switch?
My car doesn't have a terminal block and the wires are individually connected to the switch and are very close to the car's metal floor.
PostPosted: Tue Apr 20, 2021 10:49 pm
Originally there should be a black terminal block to keep the female spade connectors in the correct orientation to fit the dip switch. You could insulate the bare spade connectors with heat shrink tubing or replace them with insulated connectors. I have joined a spare plug with connectors to an old harness on one on my Minis years ago.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed Apr 21, 2021 6:47 am
I’ve just had mine off the car Bill (and it might be a bit different to yours) and it has insulated spade connectors and also a foam/rubber gasket between the switch and the body.
PostPosted: Wed Apr 21, 2021 8:09 am
1970 Round Nose
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Wed Apr 21, 2021 9:06 am
Does anybody know if this type of dip switch used all the way through 1970?
Reason I ask is my June 1970 K had the dip on the indicator stalk when I bought it and I want to know if that is correct or not.
Not really important as I have replaced the stalk with a second hand UK MkII type as I wanted to have headlamp flash - I'd just like to know.
Cheers, Paul.
1970 Morris Mini K
PostPosted: Wed Apr 21, 2021 11:09 am
Cheers, Paul.
Thanks for all your replies. Especially the photo from cgo.
I am missing that terminal block. My son suggests the original switch may have burnt out and taken the block with it - as it was an SPO41 car and the police had driving lights with full current load going through it.
-Tim: I think your switch is the round base style, same as my '66 mini; and was replaced by the smaller style.
Paul's comment above was a question I was also going to ask. The Mini King parts catalogue states the smaller switch was used up to 1968, but cgo's photo shows they were still fitted in 1970.
I have just found a NOS unit and it is dated '1584'.
PostPosted: Wed Apr 21, 2021 11:14 am
It’s not the same plug as the headlight bulbs? Or the flasher unit?
PostPosted: Wed Apr 21, 2021 11:34 am
I just pulled the carpet up on mine and answered my own question:
Another source of wet carpets now eliminated!
1970 Morris Mini K
PostPosted: Wed Apr 21, 2021 12:12 pm
This is the dipper switch and plug on my SPO41 car. I'm certain it hasn't been replaced previously.
The black plastic plug is slightly deformed through overheating, almost certainly for the reason Bill B stated. I tried to find a new replacement plug but didn't succeed at the time. Had trouble getting the BMC part number and the AMP parts lists didn't seem to show it. The local wiring outlet did not recognise the make or model. It still works OK so will just leave sleeping dogs lie.
PostPosted: Wed Apr 21, 2021 5:42 pm
In the end, it will still work without using the terminal block.
Thanks for all the comments.
