It is currently Wed Aug 20, 2025 5:25 am
PostPosted: Fri Jan 01, 2021 6:03 pm
Does anyone know what the factory distance is between the wheel mounting hub (Where the wheel bolts on) to the wheel arch for a disc brake car.
Trying to work out how much overhang a particular set of wheels will have past the wheel arch for determining arch size. (I know width and offet).
Thanks
PostPosted: Sat Jan 02, 2021 6:57 am
The front wheel track should be 1205mm originally. you should be able to work it out from that.
Cheers Dave.
PostPosted: Wed Jan 06, 2021 7:19 pm
Thankyou
