It is currently Fri Jul 18, 2025 12:40 pm
PostPosted: Sun Dec 20, 2020 3:26 pm
Hi,
1. Requesting some idea's what a Genuine Mk 2 Cyl head MOWOG 12G940 with rocker gear and new old rocker shaft is worth. I have most of the Valves, springs if required. Has been cracked tested and cleaned last week. All good no cracks and cleaned up well.
2. Mrk 2 twin carb set including air cleaner, heat shields, manifold etc. Needs rebuild kit.
Looking for a fair price of what they are worth without overpricing.
Thanks CoI
Wangaratta VIC
PostPosted: Sun Dec 20, 2020 4:12 pm
More pictures would help and your whereabouts!
PostPosted: Mon Dec 21, 2020 5:47 am
It's not a mk2 mainfold
PostPosted: Mon Dec 21, 2020 10:15 am
This is a list of manifolds for twin SUs on minis. Mk2 in Aust used one of the bottom 2 examples. These had a large mounting flange to allow for fitting different stud patterns for either twin HS2 or offset for twin HS4 - as in police specification.
https://www.ausmini.com/forums/viewtopi ... ds#p973329
Your manifold will be for earlier cars like Mk1 S, but will still suit HS2.
