It is currently Tue Jul 01, 2025 6:53 pm
PostPosted: Tue Nov 10, 2020 11:57 am
Hi All
I just needed to know what material they used to undercoat (inside wheel wells, and underbody) on an Australian mini.
Mine needs to be re done. Looks like the outer skin is peeling but does not expose metal. Can I remove all the loose coating and paint it again with the same stuff? Or is there a better material I can use without taking it back to bare metal
Cheers ImageImage
Sent from my SM-N986B using Tapatalk
PostPosted: Tue Nov 10, 2020 7:15 pm
remove the old proofcote. undercoat and apply stone guard ,pressure pack spray
Allen
PostPosted: Tue Nov 10, 2020 7:34 pm
My amateur understanding of these coatings as they are now used is that the underside of the floor is referred to as 'sound deadener' - has a ripple finish but a colour coat won't adhere to it well (the factory never colour-coated under the floor anyway); the wheel arches are coated in 'stone guard' which is also a ripple finish but can be colour-coated as per factory finish.
Users browsing this forum: crisonic and 98 guests
