It is currently Tue Jul 01, 2025 6:22 am
PostPosted: Fri Oct 09, 2020 7:44 am
Mine needs replacing but can’t find one anywhere either here or UK?
It the one that protects the harness as it passes thru the dash parcel shelf to below. Anyone have a spare they are willing to part with?
PostPosted: Fri Oct 09, 2020 10:21 am
I had some of this info ready to hand as I need one as well:
Part No. 3H1457
Quick Google showed this link:
https://www.mgsales.com.au/products/3h1457
That has the size as 1 3/8 x 3/4 and $3.51
I have used Clarkes Rubber as a good source for grommets and they have that size (35x19mm) for $2.55
1970 Morris Mini K
PostPosted: Fri Oct 09, 2020 12:47 pm
This is the grommet I have and willing to part with.
PostPosted: Fri Oct 09, 2020 2:26 pm
Thanks for the replies. Someone local to me has offered one, but I’ll keep the other offers and info in mind. Thanks.
PostPosted: Sat Oct 10, 2020 8:14 am
If stuck you can also use a piece of 10 mm split convoluted tubing and slide it around the edge. it will give good enough protection too.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 122 guests
