It is currently Thu Jul 03, 2025 6:50 pm
 Post subject: UK Van differences
PostPosted: Wed Sep 23, 2020 11:57 am
Hi all
I'm looking for my next project and am thinking about buying an early 80's clubman van shell imported from the UK which is in great condition, I would like to use parts from a banged up 78 Leyland van I have. Will the subframes and other bits and pieces for the build be compatible?
I know the doors are different but are there any other issues I may face?
Thanks in advance for your knowledge.
Benn
 Post subject: Re: UK Van differences
PostPosted: Wed Sep 23, 2020 4:00 pm
that's interesting - the UK didn't have clubman vans... it may have had its front replaced with clubman panels but are you sure it's not an estate?
have a look at the doors - does it have external door hinges?
edit: but otherwise everything except the front subframe should be basically compatible, the front subframe is a little bit different in the way it mounts so you might need to stick with an English front subframe
PostPosted: Wed Sep 23, 2020 8:05 pm
Thanks Simon.
Yep, it's an estate with internal door hinges with a 'square nose' front.
Will the engine, suspension & brakes from my Australian Van all bolt on to an English subframe?
Thanks again for your help.
PostPosted: Thu Sep 24, 2020 7:35 am
Yep, and nice find!
PostPosted: Thu Sep 24, 2020 3:15 pm
And, as it sounds like you're starting off with an Estate shell, you have a lot more options than finishing it as a simple van :D
Is it coming with the rear side windows etc installed (or available)?
Cheers, Ian
PostPosted: Fri Sep 25, 2020 9:27 am
I believe it has all the parts and glass needed for the sliding side windows and have seen the rear seat, my wife is keen on something the whole family can fit in unlike my current van.
I have young kids so need to investigate anchor points and rear sash seat belts, I've seen pictures online of UK estates so think it will be ok but need to check before I get too excited.
PostPosted: Fri Sep 25, 2020 10:01 am
Rear lap belts won't be a problem.
Based on my car I would say that 3 point belts would be a major engineering issue.
IMHO the Estate is the most practical Mini ever.... don't know why they didn't sell truckloads :)
Cheers, Ian
