It is currently Fri Jun 27, 2025 12:11 am
 Post subject: Leaded to unleaded
PostPosted: Tue Sep 15, 2020 9:00 am
Does anyone know the approximate cost of converting a head to run unleaded fuel? I suspect I have a burnt valve in number 3 but I'm yet to take the head off. So I thought I may look into this as I'm not having great success with Flash Lube.
 Post subject: Re: Leaded to unleaded
PostPosted: Tue Sep 15, 2020 10:26 am
I was quoted $400 this year for surface skim, seats, seals and re-assembly of the head.
1970 Morris Mini K
PostPosted: Tue Sep 15, 2020 10:50 am
That's cheap
Who quoted that?
Sent from my SM-G975F using Tapatalk
PostPosted: Tue Sep 15, 2020 12:01 pm
Reason for the edit:
I did provide the name, but then changed my mind - i'm not sure if the the company who quoted would still be able to meet that quote in the current climate.
Also not sure on the forum policy for these sort of things. I will check before updating.
Cheers, Paul.
1970 Morris Mini K
PostPosted: Wed Sep 16, 2020 12:41 pm
Mine cost me $500, that was a full head service and conversion - pretty sure that included the new valves as well.
67 Van, 1275cc
PostPosted: Wed Sep 16, 2020 4:22 pm
I had 1 head converted years ago, poorly and for a lot of $$. Ran other minis with Flashlube. Then gave up using additive and have had no problems on low mileage cars. I don't think the conversion is worthwhile for most minis today.
There are other posts on here that say the same.
PostPosted: Wed Sep 30, 2020 8:53 pm
I've only heard that unleaded seats can fall out and bomb it. Run 98.
Sent from my SM-A515F using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Wed Sep 30, 2020 10:17 pm
98 has nothing to do with unleaded or leaded fuel heads.
I have unleaded seats in all of my A series engines, no worries. I wonder how factory alloy headed modern cars go? seats fall out?
PostPosted: Fri Nov 18, 2022 8:26 pm
Who does leaded to unleaded Mini heads in Newcastle?
PostPosted: Sat Nov 19, 2022 9:08 am
Don't know about Newcastle but Graham Russell does many in Sydney.
