It is currently Wed Jul 02, 2025 2:46 am
 Post subject: Su jetting
PostPosted: Fri Sep 04, 2020 8:31 pm
Hi all,
I have a mk1 Cooper s motor. It has been bored to 1330 with Russell Engineering pistons, and standard Cooper s crank, has a RE266 cam. The head is ported and polished aNd I’m running twin 1/12 inch su’s.
My question is, what is the set up you would use to tune the su’s, and which plugs you would use.
Thanks in advance.
Daniel
 Post subject: Re: Su jetting
PostPosted: Fri Sep 04, 2020 8:36 pm
#6 needles were good when I had a similar spec
PostPosted: Sun Sep 06, 2020 4:21 pm
Thanks
PostPosted: Sun Sep 06, 2020 5:07 pm
Number 7 same at idle and off idle but it is a but a bit richer every where else .Even CP4 didnt work for me
PostPosted: Mon Sep 07, 2020 4:22 pm
the trouble im having is it idles fine, but really rich at higher revs.
PostPosted: Mon Sep 07, 2020 5:26 pm
So what needle and spring do you have now?
PostPosted: Thu Sep 10, 2020 7:12 am
I ran #6 needles in the 1293 with Ramflo filters.
A/F meter on the dyno drew a straight line.
It ran a Wade cam and 1.44 Corolla rockers.
PostPosted: Thu Sep 10, 2020 5:44 pm
NGKBP6ES plugs for casual road driving, BP7ES plugs for being driven hard
Users browsing this forum: No registered users and 118 guests
