It is currently Fri Aug 22, 2025 8:19 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 564, 565, 566, 567, 568  Next
PostPosted: Mon Aug 24, 2020 11:56 am
Stuwey wrote:
Got the rebuilt engine in and running. Immediately spewed oil out the transfer case, so gotta go back and do the primary gear seal.
A bit deflating after so much work, but whaddaya do. Bastard cars!
That’s sucks mate . I’m fearing the same thing in the next couple of weeks .
Head up . You be driving around in no time
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Mon Aug 24, 2020 11:57 am
The fun begins !
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Aug 26, 2020 8:03 pm
I dyecheck crack tested some cranks for friends this week.
1x 1275 big journal
3x 1275S
2x 1098
1x 998.
Most checked fine.
One of the 1098 ones was cracked. It had been
reground to -0.010" by persons unknown and the fillet radii not maintained. BANG!
Be careful buying 1098 cranks, always crack test em first. Ditto 1275 ones.
But 998s seem more bulletproof.
Last edited by drmini in aust on Wed Sep 02, 2020 8:41 am, edited 1 time in total.
PostPosted: Mon Aug 31, 2020 6:33 pm
Fixed an annoying rattle - turned out to be the 2 piece roof lining metal tabs that hadn't locked in and were rattling against each other at certain revs right above our heads.
Also fitted some sound deadening! Man, what a MASSIVE difference, with the singe biggest impact coming from lining the spare wheel and behind the rear seat. The drone that was pretty horrendous at almost any speed (to the point were I actually changed the rear muffler - but that made little difference) has all but disappeared. Also did some under bonnet deadening - all the floors and firewall were done during the build. I'm now thinking that it might be worth putting a radio in as I could probably hear it now!
PostPosted: Mon Aug 31, 2020 9:19 pm
Painted my worn seats.
Sent from my SM-G975F using Tapatalk
PostPosted: Wed Sep 02, 2020 8:36 am
Great result clip. I had a really annoying rattle in the dash area. Disconnected the speedo and no better.
Took the dash cards out and found the nut had dropped off the metal “L” bracket and was rattling away. Now I can actually hear the engine reving nicely.
Getting ready to change the old poly engine steady bushes to rubber also.
Time for some proper sound deader for me soon too.
PostPosted: Wed Sep 02, 2020 9:46 am
minimate wrote:
I had no idea how much booming resonance was a result of the boot not being sound deadened. I stumbled across it when looking at the standard features of some of the Cooper S models, and they included sound deadening matting in the bottom of the spare wheel and under the rear parcel shelf.
PostPosted: Wed Sep 02, 2020 1:55 pm
clip wrote:
And, 3 separate insulation pieces in the boot lid!
PostPosted: Wed Sep 02, 2020 5:04 pm
Haven’t done the boot lid yet, that might make it even quieter :D
PostPosted: Sun Sep 13, 2020 6:47 pm
Had my supercharger kit arrive, mocked it up......fits well.
PostPosted: Sun Sep 13, 2020 6:51 pm
So who does that kit - and how does it compare to your previous one?
PostPosted: Sun Sep 13, 2020 8:38 pm
This is from jonspeed in the Uk, uses a better tensioning system, nicer finish on the welds.... obviously has a hif not a Chinese Weber. And about 2K cheaper :shock:
PostPosted: Mon Sep 14, 2020 8:54 am
Very nice! Looking forward to seeing what you think of it when up and running :D
PostPosted: Wed Sep 16, 2020 6:57 pm
Spent the weekend stripping the rear subframe and getting it into primer. Over 5kg of compacted soil and dust removed. Interestingly there was not even one bit of surface pitting. Front subframe next.
1963 Morris Mini 850 - Blue
1963 Morris Mini 850 - bare shell
1975 MGB Roadster - undergoing 3.9ltr V8 conversion
1998 Ducati M900 Monster
PostPosted: Sun Sep 20, 2020 3:05 pm
Dyno time on the new engine build.
Users browsing this forum: Bing [Bot] and 90 guests
