It is currently Wed Jul 02, 2025 12:20 am
 Post subject: 998 valve brand options
PostPosted: Fri Aug 07, 2020 11:00 pm
Hi everyone,
In my NA 998 I think I'm going to run a 1.156" inlet and 1.062" exhaust. (If it helps, I'm thinking ~10:1 CR with flat tops, about +0.040, I'm running std rockers and a road cam (RE13/266/276 type of range) and std pressure double valve springs. Conservative home throat porting job and valve de-shrouding of head as per GR/Vizard )
Just after advice on good options for valves. I see GR does an exhaust valve of the size I've mentioned. From his website I can't see if he does the inlet size I'm after? I am just trying to decide which I should choose such as:
* standard part number valves of my chosen sizes vs other manufactures eg GR or another manufacturer
* collet types - is it okay to mix ex vs in collet types?
* stem lengths or thicknesses
* (or ideas on whether you think my valve sizes I've chosen are appropriate...)
PostPosted: Fri Aug 07, 2020 11:17 pm
Eg if looking at std type valves, would i be better with
or
PostPosted: Sat Aug 08, 2020 6:35 am
I did an 1100 head for a mate's 68mm bore 1108, I used 1.219" 998 Cooper inlets and 27mm exhausts. GR profiled the valve seats and I did a little porting.
You can mix collet types ok but keep valve lengths the same. I used 7000rpm valve springs from Karcraft. Cam is GR's 266SS.
Edit
You could use a 998 head but there's a lot more metal to remove.
PostPosted: Sat Aug 08, 2020 10:11 am
Edit
Thanks Doc. I thought the 1.219" inlet might be too big for my purposes, but do you think that's a good option for me given the specs I'm looking at?
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Sun Aug 09, 2020 5:22 am
Definitely.
PostPosted: Fri Sep 18, 2020 7:43 am
or
What springs are you planning on using, I was thinking of turning down some 1300 valves to cooper sizes and using 1300 springs as I have so a good supply of 1300 valves and a lathe.
would this work okay
PostPosted: Fri Sep 18, 2020 7:49 am
Hi Bernard,
If using 1300 valves you need 2mm shims under the rockers, and 3mm under the 998 double springs. 12mm flat washers work here.
Because 1275/1300 valves are about 2mm longer.
I have a ported 295 head here with 1300 (Morris 1100S) standard valves.
I will SMS you a pic.
Edit
I would use stock 1300 inlets and turn the exhausts down to 27mm.
Last edited by drmini in aust on Fri Sep 18, 2020 8:24 am, edited 1 time in total.
PostPosted: Fri Sep 18, 2020 8:24 am
Hi Kev can I use 1300 valves to match the valves, I always check seat pressures and rocker geometry
PostPosted: Fri Sep 18, 2020 8:26 am
You mean springs? Yes if you check pressures and install height.
