It is currently Fri Aug 22, 2025 10:17 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 563, 564, 565, 566, 567, 568  Next
PostPosted: Tue Jul 28, 2020 4:52 pm
Thanks Bill. Deliberated for a while about whether to switch out the original wheel. No regrets as the new wheel looks great and makes for a much nicer drive
Sent from my SM-A305YN using Tapatalk
1970 Cooper S SPO41
PostPosted: Tue Jul 28, 2020 6:15 pm
Milatsmadmini
this was last week...
but went and visited him and Wayne at MWA!
Might or might not make Rylstone... but have a back up rally car anyways!
On another note, how does one put a woodruff key back into a crank?
PostPosted: Tue Jul 28, 2020 6:19 pm
pdpsing wrote:
Installed a Walsall Wheels steering wheel. Took a week of sanding, varnishing and polishing to restore it to its former glory. Worth the effort. Also received the restored Britax rear seat belts from Denis Williams and fitted them - did a great job.
Are they Holden belts?
PostPosted: Tue Jul 28, 2020 6:33 pm
The buckles look the same as the ones fitted to early HQ but they had the Holden emblem, these would probably be generic accessory belts sold by parts stores.
I remember when the most common use for these belts was using the tongue as a bottle opener.
PostPosted: Tue Jul 28, 2020 6:46 pm
Bought them on eBay. Came from back seat of a Holden, EH from memory with Britax, not Holden stickers. So, assume it was an after market fitting that could conceivably be fitted to a Mini of 1970 vintage such as mine. Denis Williams suggested it was correct for that time period. Webbing was picked to match those on the front belts.
1970 Cooper S SPO41
PostPosted: Sun Aug 09, 2020 3:42 pm
Made brackets to bolt the radiator to the body, and installed thermo fan.Image
PostPosted: Sun Aug 09, 2020 7:16 pm
Nice fabrications for sure. Have you left the standard fan in place, or removed it?
PostPosted: Mon Aug 10, 2020 7:20 pm
It will only have the thermo fan. The shroud can still be fitted if needed, but I will leave it off and see how it goes.
PostPosted: Fri Aug 21, 2020 5:33 am
Said I’d never do it again, but I went and brought another supercharger setup.
I must be sick in the head
PostPosted: Fri Aug 21, 2020 9:16 am
Suggest you get it crack tested :idea: :D
PostPosted: Fri Aug 21, 2020 9:18 pm
:lol:
PostPosted: Sat Aug 22, 2020 6:27 pm
Rebuilt the wiper motor and made a washer bottle bracket
PostPosted: Sun Aug 23, 2020 12:42 pm
Just a quick oil change, filter and a bit of cleanup of the engine bay.
PostPosted: Sun Aug 23, 2020 9:56 pm
Got the rebuilt engine in and running. Immediately spewed oil out the transfer case, so gotta go back and do the primary gear seal.
A bit deflating after so much work, but whaddaya do. Bastard cars!
PostPosted: Mon Aug 24, 2020 10:36 am
Finally dropped the front subframe and engine out and removed the steering rack. Just a bare shell now. Rotisserie build next.
1963 Morris Mini 850 - Blue
1963 Morris Mini 850 - bare shell
1975 MGB Roadster - undergoing 3.9ltr V8 conversion
1998 Ducati M900 Monster
