It is currently Sun Jul 06, 2025 4:19 pm
 Post subject: petrol conversion
PostPosted: Thu Jun 18, 2020 1:24 pm
Hi there, new to this forum, and wanting to get into mini's, my question is: if all mini's are pre 2000 and only take take leaded fuel, what are owners doing nowdays to run their mini???
wbettsman
 Post subject: Re: petrol conversion
PostPosted: Thu Jun 18, 2020 1:32 pm
wbettsman
98 octane works ok. Some people like to add a lead substitute. Some use hardened valve seats. All depends on the amount of use and personal preference I suppose.
PostPosted: Thu Jun 18, 2020 1:38 pm
Great thanks for the reply.
PostPosted: Thu Jun 18, 2020 3:58 pm
Not all minis pre-2000 were leaded. The cars built built somewhere around 88-90 were okay for unleaded from factory.
Lots of engines have also been rebuilt these days at some stage or another and were probably converted too.
PostPosted: Thu Jun 18, 2020 5:42 pm
Depending on the type of engine you choose 98 octane fuel can be a real waste. And a $16 (ish) bottle of Flashlube will treat 1000 litres of fuel should you not have hardened valve seats.
Cheers, Ian
PostPosted: Fri Jun 19, 2020 12:08 am
I find mine runs better on the 95RON than the 98 and I put a 20ml syringe in the tanks and works well. Oh to get my hands on some tetraethyl lead and see what happens...apart from a fine I suppose
Rob Forsyth
Miniot!!
PostPosted: Fri Jun 19, 2020 6:58 pm
I agree with 1071S . Engine compression is the main determinant of octane needs, which engine do you have?
