It is currently Sun Jul 06, 2025 10:33 am
 Post subject: Clubman Heater hoses
PostPosted: Tue May 26, 2020 10:07 am
Hi All,
Quick question - I am wondering which way around the heater hoses go on the clubman heater? Or does it matter?
One goes to the outlet on the cylinder head and the other seems to run down the the bottom tank of the radiator.
I had to pull the heater out at one point and forgot which way they go back onto the heater tap... (I know should have written it down or taken a picture!)
Thanks
 Post subject: Re: Clubman Heater hoses
PostPosted: Tue May 26, 2020 11:02 am
The bottom radiator hose will have a small hose protrusion moulded into it half way down. The heater hose connects to it. There's a small copper pipe insert that connects the two. Cars without a heater have a different bottom hose without the protrusion.
PostPosted: Tue May 26, 2020 1:00 pm
When I fitted the Mk1 Cooper style heater to my K i connected it this way:
- heater matrix upper (outlet) connects to radiator bottom hose
- heater matrix lower (inlet) connects to cylinder head via the heater valve
1970 Morris Mini K
PostPosted: Tue May 26, 2020 9:09 pm
Being a Clubman it should go from the head outlet to the heater tap on the heater core. The other connection on the heater core then goes to the radiator pipe. Hope that's clear enough for you.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed May 27, 2020 8:29 am
Thanks for the info everyone. I am really just wondering if it matters which way it goes through the heater tap?
PostPosted: Wed May 27, 2020 11:39 am
I think that one way would be warmer than the other. Hottest part of the engine is at number four cylinder and the coldest part would be after the water has travelled through the radiator and heading back into the engine. Scoop is right I think.
PostPosted: Wed May 27, 2020 12:05 pm
Makes sense. Thanks!
PostPosted: Thu May 28, 2020 9:41 pm
I used that logic as my answer!!
5/72 Clubman Gt
Users browsing this forum: slide and 79 guests
