It is currently Fri Jul 04, 2025 9:26 pm
 Post subject: Cooper S crank
PostPosted: Tue May 12, 2020 9:35 am
Hey all, now been offered an AEG480 crank, it's on Std/Std.
Any thoughts on a value, I know its subjective and it's worth what someone is willing to fork out, but I'd like people's opinions.
There is some mild pitting on the nose, I'm in talks with my local engineering shop on if this is an issue or can be remedied.
I managed to get a thin flange S block and set of aeg177 rods, so it makes sense I need the corresponding crank.
 Post subject: Re: Cooper S crank
PostPosted: Tue May 12, 2020 9:41 am
I wouldn't worry about the pitting, my S crank laid under a house 14 years and got pitted there. It's run fine for 20 years since.
PostPosted: Tue May 12, 2020 9:42 am
Awesome, thanks for that. Was worried about paying good money for scrap :shock:
PostPosted: Tue May 12, 2020 9:53 am
What size are the journals? as in well worn or still have plenty of meat? Critical information for a used crank...
PostPosted: Tue May 12, 2020 9:58 am
As above its on Standard/Standard
PostPosted: Tue May 12, 2020 10:47 am
Ditch the 177 rods and get 521s. At least you can use ARP bolts with them. I reckon the crank has to be worth $800 to $1000.
PostPosted: Tue May 12, 2020 11:21 am
$50
Richard
PostPosted: Tue May 12, 2020 11:31 am
Crack test it...
Rumour has it they get brittle with age.
Having said that, mine ain't cracked yet (touches wood) ;)
PostPosted: Wed May 13, 2020 3:30 pm
Crack test it...
Don’t tap the noggin too hard Kev!
Rob Forsyth
Miniot!!
Users browsing this forum: jpodge and 77 guests
