It is currently Fri Jul 04, 2025 2:09 pm
PostPosted: Mon May 11, 2020 10:51 am
Iv'e got these 2 engines (to be delivered this weekend) and am noticing subtle differences between them from the pics. In the second pic, there are what looks like cut off hoses just below the spark plugs - but in the second pic, they aren't there. Can anyone shed some light on the differences in engines or school me :) Or tell me what engines I have here. Cheers
PostPosted: Mon May 11, 2020 11:21 am
Assuming the engine heads and Carbies etc havnt been changed they are both 998cc rod change engines.
Both engine number prefixes should begin with 99. This number pad can be found on the block just below spark plug 1.
If the prefix is 10 then it's an 1100cc.
Sent from my SM-N960F using Tapatalk
PostPosted: Mon May 11, 2020 11:30 am
Cheers for the info - do you have an idea about the parts that look "cutoff" just below the spark plug there?
PostPosted: Mon May 11, 2020 12:30 pm
Air injection into exhaust ports.
Used in late 998 engines which had an air pump.
Part of the emission control system.
PostPosted: Mon May 11, 2020 12:36 pm
As the doc said.
They were metal tubes that pumped air into the cylinder via a small compressor that bolted above the alternator on a bracket that came off the thermostat housing.
Pretty much a non existent setup now days.
PostPosted: Mon May 11, 2020 12:38 pm
The air was pumped into the exhaust ports, downstream of the valves. Not into the cylinders.
PostPosted: Mon May 11, 2020 12:40 pm
Yes sorry doc, should have worded/explained it better.
Thanks
PostPosted: Mon May 11, 2020 1:16 pm
Thank you very much - great info! So in saying that, with this engine, do I need to source a compressor to make it function or can the tubes be welded (forgive my inexperience) closed.
PostPosted: Mon May 11, 2020 1:19 pm
No, you don't need to find a compressor. The tubes have been cut off and probably soldered over, they'll be sealed well enough for what they do. You could take those cut-off pieces out and replace them with grub screws to make it tidier
PostPosted: Mon May 11, 2020 1:25 pm
Great! Thank you :) I'll do exactly that with the grub screws.
PostPosted: Mon May 11, 2020 1:38 pm
For reference this is what the Exhaust Port Air Injection looks like
PostPosted: Mon May 11, 2020 2:31 pm
The grubscrew size is 7/16 UNF.
Or if you're a cheapskate like me, use old seatbelt bolts and grind em flush.
PostPosted: Mon May 11, 2020 2:52 pm
LOL Thank you so much! I was sitting here thinking, how the heck am I going to find the size I need.. :) Legend
PostPosted: Mon May 11, 2020 2:58 pm
The emission equipment was part of Australian Design Rule 27A and is no longer required, ADR27A has been repealed and no longer exists. (despite what a couple of self appointed trolls say)
You can't buy leaded petrol any more to make it work properly anyhow.
PostPosted: Mon May 11, 2020 3:30 pm
Further reading...
https://www.rms.nsw.gov.au/about/enviro ... dards.html
https://www.infrastructure.gov.au/vehicles/environment/
