It is currently Fri Jul 04, 2025 4:04 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Engine Vibration
PostPosted: Sun Apr 26, 2020 9:41 pm
MINI66 wrote:
In your opinion is 37 grams a lot to be out of balance for the flywheel?.
If you believe MED, with their lightweight flywheels, anything over 1.0 gram is over their tolerance.
https://www.youtube.com/watch?v=xC3oxFP0xtk
PostPosted: Sun Apr 26, 2020 10:00 pm
True. Thanks clip
Sent from my SM-G950F using Tapatalk
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 10:20 pm
I really hope that fixes it for you.
PostPosted: Sun Apr 26, 2020 10:23 pm
Yeah thanks, me too. Doesn't help your quest though. Maybe you should double check you fw as well?
Ford DF LTD - 5Ltr
PostPosted: Sun Apr 26, 2020 10:34 pm
Pm sent :D
PostPosted: Wed May 13, 2020 4:19 pm
Just a quick update.
New balanced flywheel has pretty much eliminated the vibration.
There is still a slight vibration at 2k which seems like a resonate frequency rev level. Possibly the natural vibration that these engines have that most people have mentioned. Very tolerable though compared to before.
New problem though, wheel nuts on new 13 x 7 JBW superlite wheels keep working loose. The back LH wheel fell off and rolled up the road and into my next door neighbour's driveway. (at 40k's).
All of the wheel nuts were located at the place of wheel departure. Smashed the Miglia arch so back to bodywork. :roll:. Big flat on drum backing plate. Checked the other wheels and were also loose. (They were all torqued up to 40 foot pound only about 5km's ago?). Will try torquing them up more and adding arrows to the nuts or nut indicators. Maybe they need to bed into the taper some more.
Ford DF LTD - 5Ltr
PostPosted: Wed May 13, 2020 4:27 pm
There is still a slight vibration at 2k which seems like a resonate frequency rev level. Possibly the natural vibration that these engines have.
Wow that’s great news! I’ll have to investigate further for mine.
PostPosted: Wed May 13, 2020 4:34 pm
Yeah, more research for you unfortunately.
Look at it this way, at least your wheels are staying on. This crap is stressing me out, always something to deal with.
Ford DF LTD - 5Ltr
PostPosted: Wed May 13, 2020 4:39 pm
I just have to ask. Did you fit new studs and were they pulled up all the way into the hubs?
PostPosted: Wed May 13, 2020 5:04 pm
Yep. Brand new 17mm nuts on brand new long studs through new spacer drums. (for the back).
Fully home on the hubs
Ford DF LTD - 5Ltr
PostPosted: Thu May 14, 2020 10:22 am
do they have steel washers or press fit steel inserts?
PostPosted: Thu May 14, 2020 10:28 am
Neither. They are a tapered nut and the wheel doesn't have inserts. (Tapered aluminium seat)
Ford DF LTD - 5Ltr
PostPosted: Thu May 14, 2020 10:40 am
With a wheel off, check that the nuts are firm (correct threadform) when threaded onto the stud.
Check how much of the stud is being engaged by the wheel nut when the wheel is on.
PostPosted: Thu May 14, 2020 11:09 am
Thanks
Ok, will do when i get home.
The studs are new and the nuts tighten up nicely with no slop/play and I have added a little grease to the stud (but not the taper).
The front wheel nuts seem to be fairing better. They are staying tight but the backs are the problem. Looking at the taper/seat in the wheels, the fronts have been off and on more times and the paint has worn off more in there. Leeds me to think that more torque on the backs will bed the nuts in harder and break through the paint like the fronts have. When doing up the nuts the final tightening makes a dry grabbing noise (from the nut in the taper). It is not smooth like the fronts.
Will try 5 5foot pound and monitor once back on the road.
Ford DF LTD - 5Ltr
PostPosted: Thu May 14, 2020 11:16 am
Get rid of any paint in the wheel nut holes...!!!
