It is currently Wed Jul 02, 2025 2:44 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Apr 22, 2020 8:25 pm
If your firewall has 6 nuts like this photo then it is a MK2 model starting from early 1969.
The top of the radiator shroud should have YG2S1 xxx, YG2S3 xxx, YG2S4 xxx or YA2S5 xxx. From the angle of the engine bay photo you supplied I think yours is missing.
The next thing to look at is the body number. Between March 1969 and May 1970 it will have a body number and body code in the drain gutter above the wiper motor. xxx 2/04, xxx 2/05, xxx 2/05A, xxx 2/06.
PostPosted: Wed Apr 22, 2020 9:12 pm
How about this for a theory? Given the wiper motor suggests that the car maybe from around 10/69 there would not have been an ID plate or compliance plate fitted on an Australian built car. Maybe a previous owner in Japan didn't know this and decided to fit a plate. Given that there wouldn't be many Minis of this vintage in Japan, a compliance plate was sourced from a wrecker from another BMC car - an MG. Perhaps to satisfy registration requirements - i.e. a compliance/ID plate was mandatory for registration. Either way Kimura san will need to look for identifiers stamped directly into the car body, e.g. on the radiator shroud.
1970 Cooper S SPO41
PostPosted: Wed Apr 22, 2020 9:14 pm
I cant see a radiator shroud in the engine bay photo. It may have one so I will wait for a better photo to come through. If not we will need to look at either the gutter above the wiper motor or the firewall behind the master cylinders for a body number and body code.
PostPosted: Wed Apr 22, 2020 10:57 pm
Good evening,
I am excited to hear your thoughts!
I am a 31 year old woman living in Japan. This mini is the second mini. and before used to have a Paul Smith white mini.
An acquaintance gave me this Australian mini. But I didn't know much about the Austrian minis. If it's an Mk2, my mini has the wrong front badge. I would like to return to my original appearance as much as possible.
PostPosted: Wed Apr 22, 2020 11:13 pm
My money says Mk2 Cooper S
PostPosted: Wed Apr 22, 2020 11:20 pm
These are the areas to check for chassis and body number stamps on a 1969 or 1970 MK2 body.
PostPosted: Wed Apr 22, 2020 11:28 pm
The lack of flares pointed towards a Mini K for me but there has been a few MK2 S's pop up without flares in the past. Hopefully we can get a photo of the chassis and body number.
PostPosted: Thu Apr 23, 2020 3:06 am
Thank you very much. You have given me important knowledge.
I know what I need to check points
Now Mini is going to the factory for painting.
There are many things to check when mini return :)
Is it likely to be mk2 at the moment?
From the engine number, I thought it was mk1.
PostPosted: Thu Apr 23, 2020 8:58 am
its got a MK2 interior and no proper chassis plate.. thats what makes me think.
PostPosted: Thu Apr 23, 2020 1:16 pm
What about the first photo that shows the drivers side floor?
I can not see the indent where the hydro lines, etc run.
This section looks more 850 / Mk1 to me (but the wiper scuttle looks Aussie Mk2 / K).
PostPosted: Thu Apr 23, 2020 2:10 pm
I noticed that too strikers on b pillar are really recessed for wind up windows
I noticed the bonnet prop on inner guard is towards the front more I would be tempted to say it could be pre mini k; mk2
PostPosted: Thu Apr 23, 2020 4:23 pm
I don't have much knowledge about Mini K.
Is the Mini K a 1100 engine?
Does that mean you might have ported the mk1 cooper S engine to the body of the mk2 mini K? :shock:
PostPosted: Thu Apr 23, 2020 4:31 pm
If you can get a photo of the firewall we can work out if the car is a Mk1 or Mk2. The chassis and body stamps will tell us what the car is and then we can work out a date.
PostPosted: Thu Apr 23, 2020 4:58 pm
One of the differences between a Mini K and a MK2 S is the length of the front guard to body join cover strip.
On the S the strip is shorter as the original type narrow guard flares had a very narrow slot width where the body join is.
The full length body join strip wouldn't fit in the narrow width slot of the flare so it was shortened by about an inch or so???
The body in the pic has a full length join strip.
The upholstery pattern is the common Mini K/Mk2 S pattern.
Looks like it is probably a Mini K shell with a MK1 1275 S engine transplant.
RonR
68 build Mk1 Cooper S
PostPosted: Thu Apr 23, 2020 6:14 pm
Ahhhhh lovely...all this Cooper S info is just gold for the how to...errggghh...put a car together :roll:
