It is currently Sun Jul 06, 2025 11:39 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 26, 2020 8:18 pm
I contacted Stedi today and they informed me that the LED headlights are polarity sensitive and therefore can’t be used with positive earth vehicles.
PostPosted: Fri Mar 27, 2020 7:42 am
If you run the LED +ve side to ground and -ve side to your switch/relay it should work with a +ve earth car.
1970 Morris Mini K
PostPosted: Fri Apr 03, 2020 8:53 pm
Yes, correct. I don’t know why Steadi would not have said just that.
PostPosted: Sat Apr 04, 2020 11:34 am
Yes, and you are right. You just need to be certain that the exposed metal surfaces(which will be used as heat sinks) do not share a common with the ground wire. Something easy in the hand to check, but harder over the internet. perhaps ask convertiblemini.
PostPosted: Sat Apr 04, 2020 12:50 pm
Mount them up in plastic headlamp buckets? Not much airflow to the heatsinks though...
At least you could decide your earth.
Roads need more corners
Users browsing this forum: Bing [Bot] and 95 guests
