It is currently Wed Jul 09, 2025 3:51 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Dec 22, 2019 7:29 pm
I bought a 1275cc engine that came out of a mortis mini 1300 auto and am going to do a rebuild, but the rebuild kits on Minisport there are 2 the 1275 not A+ and the copper s 1275. Is mine an Non A+?
PostPosted: Sun Dec 22, 2019 8:23 pm
Engine prefix 12H169H, 12YAAH and 12YEAH are A series Automatic engines (not A+).
The casting number at the back of the block is probably 12G 1279 which is the standard 1275 A series Non S casting.
PostPosted: Sun Dec 22, 2019 9:53 pm
So it's not an A+. Ok thanks
PostPosted: Mon Dec 23, 2019 1:00 pm
That would have been a "dead" mini 1300?
If you plan using the auto block in a manual setup, are you aware that some changes to the block are needed?
There is an detailed explanation on Ausmini:
viewtopic.php?f=25&t=90470
PostPosted: Mon Dec 23, 2019 1:23 pm
you do need to be a little bit careful - the two different sets they're talking about there aren't really A+ v's A series, it's the size of the crankshaft's conrod journals - A+ used the larger size, however Morris 1300 engines came in both sizes. You need to identify the crankshaft before you order anything.
PostPosted: Mon Dec 23, 2019 2:03 pm
Well there you go. I did not know that Morris 1300's came out in a small journal. I knew that the Morris 1100S did.
PostPosted: Tue Dec 24, 2019 9:17 am
I'm only going by the auto 1275 I have in my garage - it has a small journal crank - I don't know if it came from an 1100S or a 1300
my advice is still to identify the crank before ordering anything
PostPosted: Tue Dec 24, 2019 10:54 am
1300 auto blocks were 12YEAH prefix.
I've had a couple, both same, with large journal cranks.
These came out after the 1100S manuals were obsolete (replaced by Morris 1500 ohc).
1100S auto early motors 12A169H were thin flange and had a small journal crank.
PostPosted: Tue Dec 24, 2019 7:13 pm
So Morris 1300s didn't come out in both sizes?
I had an original Morris 1300 and it was large journal too.
PostPosted: Wed Dec 25, 2019 3:50 am
@TK,
Small journal crank was long gone by the time Morris 1500 manual and 1300 auto cars replaced the 1100S.
PostPosted: Sun Dec 29, 2019 8:57 am
Last edited by Woody_Woodvine on Sun Dec 29, 2019 9:08 am, edited 1 time in total.
PostPosted: Sun Dec 29, 2019 9:00 am
PostPosted: Sun Dec 29, 2019 9:20 am
Large journal. Now just to get it measured and crack tested and machined and then start to worry about the bearings you need to buy.
PostPosted: Sun Dec 29, 2019 9:35 am
I wanted to get it up to 1380cc and I know it will need a new crank with a longer through, new pistons due to the larger bore. Do I still need need to get the right journals?
PostPosted: Sun Dec 29, 2019 9:54 am
a standard stroke with oversize pistons can get you to 1380. Remember to offset bore the block.
Why do you need a new crank?
Users browsing this forum: 1071 S, John Sneddon and 80 guests
