It is currently Thu Jul 03, 2025 11:17 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 559, 560, 561, 562, 563, 564, 565 ... 568  Next
PostPosted: Tue Nov 05, 2019 4:51 pm
Stuwey wrote:
Drove it to Minis at the Mill for the day... Tappet getting louder and louder on the drive up there. Not ideal.
Trailered it home, checked the clearances yesterday - Motor is now out. No doubt a trashed cam and /or follower. Motor's only done 760 miles :(
Your Ausmini signature tag line might be your curse!
But, seriously I am interested to know the final wash-up.
PostPosted: Wed Nov 06, 2019 8:03 am
Well, I can assure you it wasn't cheap :lol:
PostPosted: Wed Nov 06, 2019 5:48 pm
They seldom are cheap. Mechanical sympathies are with you.
It always gets better on the other side of a disaster.
PostPosted: Thu Nov 14, 2019 7:29 pm
Re-kitted 7.5" brake calipers, new seals and pistons, after calipers were blasted and zinc plated by local brake specialist.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Nov 16, 2019 11:29 am
Found out why my battery has slowly discharged for the last 20 years!
It had a 45mA parasitic current drain. After disconnecting the 2 white wires from the ignition switch they had 0.71V on them.
The culprit was the 16ACR alternator, it was discharging its 0.71V through the charge light, and into the coil with ign switch off.
Now running another NOS 16ACR I bought 15 years ago. :)
PostPosted: Sat Nov 16, 2019 4:06 pm
8)
PostPosted: Wed Nov 20, 2019 9:53 am
Milatsmadmini
Installed diff.
Found out that I had snapped a brake line somewhere along the way.
Put on the extractors.
Half installed bottom pulley before also discovering that it wont go on flush (still TBD why) ?woodruff key or too much shim.
Mock tested belts
Went to try putting pots onto shafts before getting annoyed that I forgot there were 2 different sizes. I just happen to have one of each (shaft) and only 2x small pots. (more annoyance)
Filed down and fitted a Gemini starter.
Wrote another long list of things to do grrrr
PostPosted: Wed Nov 27, 2019 9:09 am
Monday: Watched her go down the street on a trailer for a little holiday.
Nick
PostPosted: Wed Nov 27, 2019 11:26 am
Drained the hydro and refilled.
50/50 Nulon green glycol concentrate and de-ionized water.
I do this every 4 years or so.
PostPosted: Wed Nov 27, 2019 12:50 pm
Doc,
Can you add metho to that recipe?
Cheers, Alan.
PostPosted: Wed Nov 27, 2019 2:21 pm
Probably could but I never have.
People in USA have used this mix in hydro for many years.
PostPosted: Fri Nov 29, 2019 8:05 am
I present to you one munted cam and follower. It'll need cam bearings, mains, and big ends. Crank will need a grind too.
Less than ideal.
PostPosted: Sat Nov 30, 2019 3:28 pm
I checked mine because it drains the battery as well, but its not leaking at the alternator... any other areas to check?
Jenk.
PostPosted: Sat Nov 30, 2019 8:34 pm
Check your Gemini starter's solenoid battery terminal resistance to ground with battery cable off. I had one with enough copper dust in it to keep the starter spinning slowly with engine stopped.
PostPosted: Mon Dec 02, 2019 8:48 pm
Overhauled and reassembled a VH44JA Model 2 for my current resto project.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
