It is currently Wed Jul 09, 2025 8:50 pm
PostPosted: Tue Nov 26, 2019 1:37 pm
I need some help.
I have just bought a pair of velocity stacks for Claude, my MK 1 970cc Cooper S. When I had a quick look at the current setup I saw that the carbie return spring was attached to the air cleaner box.
So where the heck do I attach that with the stacks installed?
Thanks in anticipation.
PostPosted: Tue Nov 26, 2019 2:17 pm
You can flip the spring to go down onto the bottom bar
PostPosted: Tue Nov 26, 2019 3:18 pm
Well that makes sense.
Thanks for that.
PostPosted: Thu Nov 28, 2019 2:19 pm
Or just leave the third one off ..depending on how you like the throttle pedal to feel......
Cheers, Ian
PostPosted: Fri Nov 29, 2019 8:15 am
Thanks Ian.
Methinks I will go with a light pedal.
