It is currently Wed Jul 09, 2025 3:43 am
PostPosted: Wed Nov 20, 2019 7:57 pm
Morbo28 wrote:
Me again!
I am replacing diff covers, speedo drive covers etc on the gearbox after changing the final drive. I noticed that the engine builder has used an orange silicon type sealant on the gaskets.
I will of course be replacing with new actual gaskets, but would you recommend I use something similar to the orange silicon stuff or use the Permatex Aviation Sealant Liquid like I used on the water pump?
If I should use silicon, do you have a recommendation?
Thanks guys!
I try and avoid silicone sealants because if overdone the excess can block strainers/ filters and small galleries. A little bit is ok. Just make sure it doesn't squeeze out when the mating surfaces are tightened up.
PostPosted: Wed Nov 20, 2019 8:10 pm
I've left behind most of the traditional sealants, and use products like Permatex Ultra Grey (Used to be also called GM Grey) https://www.permatex.com/products/gaske ... t-maker-2/
This stuff is used for modern engine construction which doesn't use gaskets anymore, so this silicone coupled with the mini's paper gaskets (because not every machined surface aligns perfectly on a 60-year-old car) gives the best of modern tech to sealing engines. My engines are ten years old with a lot of good road use and the joints are still excellent.
PostPosted: Thu Nov 21, 2019 4:29 am
I use Permatex ultra black silicone sealant on timing cover because it's never flat.
Everywhere else I use either Loctite 515 or Permatex anaerobic gasket maker.
I currently have NO diff side cover gaskets to save using a pile of shims (current sold gaskets far thicker than originals).
No leaks there in 20 years.
PostPosted: Thu Nov 21, 2019 5:43 am
Thanks guys, your help is appreciated!
Sent from my Pixel 2 XL using Tapatalk
