It is currently Fri Jul 11, 2025 4:30 am
 Post subject: Gear lever boots
PostPosted: Thu Feb 09, 2017 1:47 pm
Does a 1966 Oz mini have the smaller "dust excluder" boot fitted inside the bigger square-section boot, visible at the base of the gear stick?
My '69 and '70 minis have this smaller boot also but there is no sign of one for the earlier mini?
Thanks.
 Post subject: Re: Gear lever boots
PostPosted: Fri Feb 10, 2017 2:30 pm
I had an idea those smaller boots arrived with Mini Ks or thereabouts when the gear changes had the large dish retainer plate holding the stick down
....you just lost him his insurance bonus!
997
PostPosted: Fri Feb 10, 2017 3:57 pm
IIRC the first OZ built Deluxe and S (not sure how early) had a remote change that used a pressed metal cup shaped piece that went up inside the base of the rubber boot (there was no inner boot) and supposedly sealed the remote change from dirt getting in. Not very successfully. Movement of the remote housing chewed up the base of the rubber boot until it wore through. My 68 S has this type and the boot has been changed several times.
The remains of a MK2 S I had used the flat disc and the inner boot.
Can you still get an inner boot?
RonR
68 build Mk1 Cooper S
PostPosted: Fri Feb 10, 2017 6:08 pm
Are you talking about wand shift? I just tried to describe mine and it was gibberish but as far as i can tell i need 3 grommets/boots..
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Fri Feb 10, 2017 6:41 pm
Our Mini K (approx. 280th car built) had the extra inner boot and large retainer plate.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Fri Feb 10, 2017 8:12 pm
The Mini King
RonR
You can use a pot joint boot in it place GSV1073
PostPosted: Sat Feb 11, 2017 7:20 am
Is this for the direct shift on the early minis?
Mine appeared to have a foam disk on it under the boot, it disintegrated when I tried to get it off.
PostPosted: Sat Feb 11, 2017 7:11 pm
I was asking about the remote type linkage on De Luxe onwards. I have no knowledge of the magic wand system.
PostPosted: Sat Feb 11, 2017 7:27 pm
Thanks for your comment. I think you are right that the 2nd boot came with the K in 1969 onwards when the gear stick mechanism was held down by a thick, flat plate and the inner boot lip went over the edge of the flat plate.
PostPosted: Sun Nov 03, 2019 4:30 pm
Bill B mentions a metal plate replacing the pressed metal retainer on the gear stick retaining mechanism to allow the fitting of a small boot to provide better sealing. Does any one have a drawing of this plate? My ageing brain seems to recall that this plate had a gate incorporated to prevent accidental engagement of reverse.Yes I may be wrong. If so the size and shape of the hole would be a huge help.
Mk1 Cooper S
Mini K Rally car
PostPosted: Sun Nov 03, 2019 8:30 pm
This is a photo of the gear stick assembly on my Mk 2 as it's off the car at present.
The plate looks to be assembled before the 2 halves are bonded together - making removal or installing one not easy. But need to look in daylight to be sure.
PostPosted: Sun Nov 03, 2019 8:49 pm
Mine has this setup
PostPosted: Mon Nov 04, 2019 5:24 am
My Sept 1970 S is exactly the same as Bill's above. The inner boot was in good nick so I cleaned it and reused it.
PostPosted: Mon Nov 04, 2019 9:28 am
There is a difference in the two arrowed parts, one is dished and one is a plate. Can't find the boot in my PUB1056M. What is the number for the parts catalog for the Mk2 Mini's? Also what is the boot part number.
PostPosted: Mon Nov 04, 2019 9:59 am
HYL3698 later numbered PUB1011 and PUB1012
GSV1073
