It is currently Wed Jul 09, 2025 2:46 pm
PostPosted: Sun Oct 20, 2019 8:07 am
Hi Guys
I notice that the rubber small rubber boot that covers the cup that holds the stick in is not available.
I have heard that you can use a pot joint boot. It is boot required? What are everyone else using?
Rick
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Sun Oct 20, 2019 10:16 am
I haven't used one for 30 years....!
PostPosted: Sun Oct 20, 2019 10:36 am
It's a dust excluder - part GSV1073 in case you want to search for one. It seems the same part is used as a boot for pot joints.
Mine was in good nick so I reused it when building the remote change extension.
PostPosted: Sun Oct 20, 2019 3:27 pm
It is to stop water and dirt from getting into the shift, it's only important if you drive the car.
PostPosted: Sun Oct 20, 2019 6:14 pm
Thanks guys.
For $6.50 I might as well add one to the next parts order.
Rick
Ford DF LTD - 5Ltr
Users browsing this forum: jpodge and 78 guests
