It is currently Thu Jul 10, 2025 2:18 pm
 Post subject: Starter 1973 Clubman GT
PostPosted: Tue Sep 10, 2019 1:49 pm
Hi Guys do I need to grease the gear that engages the flywheel? Do you also know where the solenoid for the starter is mounted?
1973 Clubman GT - YG2S8 1637
PostPosted: Wed Sep 11, 2019 6:01 pm
I don't. Grease will mix with dust from the clutch plate with the potential to gum things up....
The solenoid lives on a bracket that attaches to the upper front of the transfer gear case. The solenoid to starter cable is generally stiff enough to set the location if you bolt one end to the starter...
Cheers, Ian
PostPosted: Wed Sep 11, 2019 6:21 pm
What Ian said.
But I put powdered graphite on the splines inside the pinion assembly.
PostPosted: Wed Sep 11, 2019 7:08 pm
This is the location and angle for the 1973 GT starter solenoid.
With the introduction of the Clubman range the starter solenoid was attached to a bracket between the engine steady and block. But for some reason all the 1206 series engines had the starter solenoid bolted to the transfer case. I think it was to give more clearance from the clutch breather hitting the steady bracket.
This was the position for the 9FXEY, 1200 and 1205 GT engines.
Here is a Clubman Van showing the bracket that goes between the engine steady and block. The same bracket was used in the Leyland mini range as well.
PostPosted: Thu Sep 12, 2019 1:01 pm
Wow thanks now is this the right solenoid?
PostPosted: Thu Sep 12, 2019 3:47 pm
Yes thats the one - Lucas 4ST.
It was first used here on the MK1 S in early 1968. They originally had a push button start but the push button function was deleted in late 68 / early 69 when the UK built No 76766 was dropped for the local version No 62933009.
Quality is a bit hit and miss with the repro ones. Some last a few months and others have no issues.
PostPosted: Thu Sep 12, 2019 9:41 pm
Can I still buy the original ones? Not a repo
PostPosted: Thu Sep 12, 2019 9:44 pm
Ebay you might get NOS of the UK made 76766. I haven't seen any NOS aussie built ones.
Here is one from the states - https://www.ebay.com.au/itm/NOS-LUCAS-S ... ctupt=true
The original ones have date stamps.
The UK one stamped here -
The Aussie one is stamped here -
I am not sure where the New Lucas solenoids are made but they do have manufacturing plants in India and Pakistan.
PostPosted: Thu Sep 12, 2019 10:25 pm
Is this better it says Lucas?
PostPosted: Thu Sep 12, 2019 10:30 pm
The new lucas built ones are not up to the standard of the originals. But you may be lucky and have no problems. I personally bought a new one and its fine but I have seen others complaining about being on their 3rd solenoid in 12 months.
Users browsing this forum: Bing [Bot] and 84 guests
