It is currently Fri Jun 20, 2025 6:49 pm
 Post subject: Interference Engine?
PostPosted: Thu Aug 29, 2019 11:27 am
Q: Is the A+ motor an interference engine? In other words, is it possible for the valves to come into contact with the pistons? I have 10:1 compression, a fast road cam, 1.5 rockers, and a standard profile crank. If my timing chain breaks or I experience valve float, will my valves hit the pistons?
Michael, Santa Barbara, CA
. . . the sled, not the flower
https://www.facebook.com/PoserMotorSports/
 Post subject: Re: Interference Engine?
PostPosted: Thu Aug 29, 2019 9:58 pm
Most likely yes, not knowing your cam and pistons.
If you were to break a double row timing chain then you have bigger problems. Valve float isn't one of them.
