It is currently Fri Jul 11, 2025 2:14 am
PostPosted: Fri Aug 16, 2019 11:25 pm
Hey all
I used a tin crank pulley because I had to weld a trigger wheel to it.
Now with the crank bolt tight the rivets in the pulley foul the timing cover.
Do these come with a stepped washer behind the bolt or a washer behind the pulley against the crankshaft ?.
blokeinamoke wrote:
PostPosted: Sat Aug 17, 2019 4:47 am
There is an oil slinger between the pulley and the crankshaft sprocket.
Also usually 2 shims behind the sprocket for chain alignment.
On the outside, a tab washer to lock the crank bolt.
Some people (including me) use Loctite 262 on the bolt instead, as the current washers are very soft and deform when tightened.
PostPosted: Sat Aug 17, 2019 8:45 am
Ahhhh thanks Kev. I am just dummying it up to align my VR sensor and bracket.
blokeinamoke wrote:
