It is currently Wed Jul 09, 2025 9:58 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Aussie GT Engine
PostPosted: Mon Jul 29, 2019 3:47 pm
Hi all,
What can anyone tell me about a motor I picked up, has 1206 stamped into the engine tag spot, which I know means GT motor, it has a cooper S gearbox under it. Are they a sort after thing for people rebuilding their gt’s or not really?
Chris
 Post subject: Re: Aussie GT Engine
PostPosted: Mon Jul 29, 2019 4:13 pm
yes - very sought after... does it have tappet chest cover side plates?
PostPosted: Mon Jul 29, 2019 5:25 pm
1206 Is an 1100S type block
PostPosted: Mon Jul 29, 2019 6:47 pm
No side plates
PostPosted: Mon Jul 29, 2019 6:50 pm
Found this on the classic register
Prefix 4: 1206 - This prefix was introduced to the GT in late 1972. Unlike the engines outlined above, this block had a solid rear wall among other features, and was closer to the 1275GT model offered in the UK and some other markets.
1206 and 1207 prefixed engines
Block rear wall: These engines were rationalised large journal blocks, with a solid rear block wall (same spec as UK 1275GT).
Crankshaft: The crankshafts in these later engines were not cross-drilled, and had larger big ends (1.75 inch compared to 1.625 inch). These cranks are stamped with part number 12G1817, and were also tuftrided, using the EN16T steel. These engines naturally also had different main bearing caps to the earlier GT engines.
Crank case ventilation: Unlike the earlier Cooper S related engines, these engine blocks have 2 CCV points located in different positions to the earlier engines. One is located on the timing chain cover plate, and the other sits on the top of the clutch housing. These were fed directly to the carbies via a plastic 4-way adaptor.
Additional engine mount: An additional engine mount was fitted to these engines from the thermostat housing to the bulkhead, into a bracket next to the windscreen wiper motor. This was in addition to the mount running from the bulkhead under the brake/clutch master cylinder, which was also present on the earlier engines.
PostPosted: Mon Jul 29, 2019 6:59 pm
Chris.Williams wrote:
No side plates
Still sort after?
PostPosted: Mon Jul 29, 2019 7:04 pm
No side plates
Still sort after?
Still sort over
PostPosted: Mon Jul 29, 2019 7:08 pm
Probably a bigger market for the 1206 in NZ because they got most of the later GTs.
PostPosted: Tue Jul 30, 2019 2:02 pm
Sought after, not sort. Just saying.......
PostPosted: Tue Jul 30, 2019 2:43 pm
Ha ha. As a senior citizen brought up on the need for correct grammar I thought the same thing, but resisted saying anything. It seems it's quite acceptable these days to misspell, abbreviate or use "text speak" when communicating, and that's OK on here. Apart from anything else our members come from very different backgrounds. If the meaning of a post can be understood that's fine.
One that does grate a bit with me is when I see a new part is brought for the car (instead of bought).
OK, enough of the grammar police intervention ... :)
PostPosted: Tue Jul 30, 2019 3:33 pm
If only a few people wanted these engines, would they then be sort of sought after?
PostPosted: Tue Jul 30, 2019 5:26 pm
Probably not as you can re-stamp any old 1100S thick flange block
PostPosted: Tue Jul 30, 2019 5:49 pm
English is a tricky language.
PostPosted: Tue Jul 30, 2019 7:12 pm
and are they glued on to a solid block :?: :roll:
PostPosted: Tue Jul 30, 2019 7:18 pm
Point taken. I'll try to be less pedantic in future.
Users browsing this forum: Bing [Bot] and 104 guests
